Here is the 383/432 short block build cost.
Complete engine, 1969 383 oil pan to intake manifold $250
Stroker crank, Scat forged crank, 3.75 stroke, OEM rod journals, Flatlander Racing $886
#4-383-3750-6760-2374
Forged flat top pistons, Diamond #51910, Flatlander Racing $640
Moly piston rings w/ napier 2nd ring, Mahle #315-0035.035 $120
Connecting rod bolts&nuts to fit OEM rods, ARP #145-6002 $67
Timing chain & gear set, 9 keyway, Engine Pro #08-2010-9 $96
Crankshaft main bearings, Sealed Power #4094M $70
Crank rod bearings, Sealed Power 8-2320CP $68
Cam bearings, Durabond #PDP-17, cam rear plug $27
Engine gasket set, Felpro #KS2110 $46
Head gaskets .039 thick, Felpro #1009 $76
Intake manifold valley pan gasket, Felpro #MS96007 $13
Intake valve stem seals, positive PFT, Sealed Power #ST-2004 $48
Oil pump, Melling #M63 $80
Oil pump drive bushing, Dura-Bond AD-584 $2
Oil pump drive shaft, Melling IS-63 $56
Camshaft, Crower #32241 $157
Lifters, Crower #66031-16 $87
Engine block freeze plugs, Sealed Power #381-8011 $13
PARTS TOTAL: $2802
Bore & hone block $200
Cut block head gasket surfaces .026 inch for zero deck $185
R&R cam bearings $55
Resize OEM 383 connecting rod big ends w/ ARP bolts $120
Heat connecting rods, install pistons/pins onto rods $48
Cut .10 inch off crankshaft counterweights (could cut 0.2 off and still balance w/above parts) $85
Doing this leaves .06 inch clearance between crank counterweight and piston pin boss
Balance rotating assy $250
LABOR TOTAL: $943
Short Block Total: $3745
