Author Topic: 1970-71 E-Body Convertibles (Manual Top "Catch")  (Read 5318 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
Re: 1970-71 E-Body Convertibles (Manual Top "Catch")
« Reply #30 on: January 27, 2014 - 03:23:56 PM »
Got a few questions about these manual top hold down brackets.  Does anyone have any info about, (or photos showing) where exactly the brackets mount inside the car?  I'm pretty darn certain the previous owner did not mount them in the correct location.  He had them bolted to the angled ends of the cross brace, and the drilled holes definitely don't look original.  Other evidence that indicates incorrect mounting were the additional "extension" pieces that he used between the bracket and the catch.  They don't look original; and from other photos I've seen of complete bracket assemblies, there were no extensions.  Also, where did the nylon catch make contact on the convertible top frame to hold it down when it was lowered into the well?  Regarding the well liner: Were the brackets mounted with the well liner underneath them, or were there "slits" made into the well liner to allow the spring steel leg to poke through (therefore, the bracket would not be seen from inside the car, only the nylon catch)?  It kinda makes sense to me that the entire bracket assembly would be visible from inside the car, hence holes would be made in the well liner for the mounting bolts.  Thanks for any help.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline filmsurgeon
« Reply #31 on: January 27, 2014 - 03:25:31 PM »
Offline JayBee
« Reply #32 on: January 28, 2014 - 07:53:25 AM »
This is the only picture I have of it. Maybe someone else has better shots or close-ups.
« Last Edit: January 28, 2014 - 07:55:33 AM by JayBee »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline filmsurgeon
« Reply #33 on: January 28, 2014 - 12:59:58 PM »
Thank you.  That's a great and very helpful photo.  I also received a photo (see attached) from a friend on the Moparts forum site.  So, it looks like the bracket's mounting bolts went through the well liner (well liner sandwiched between the bracket's base and the cross brace).  Any other photos would be greatly appreciated.  Thanks.
« Last Edit: January 28, 2014 - 01:03:51 PM by filmsurgeon »
Offline filmsurgeon
« Reply #34 on: January 29, 2014 - 05:25:49 PM »
It's become pretty clear to me now why my manual top catch bracket assemblies had the tubular extension pieces (the extension pieces measure 3-3/8").  It's because the previous owner did an approximate 3" mini-tub to the rear wheel wells.  Apparently, he also shortened the cross-brace as part of this mod.  Looks like I'll need to reuse the extensions.  When the bracket is placed over the mounting holes on the cross-brace, the nylon catch is about 3+" from the point where it needs to catch the frame.  See attached photos for measurements of rear wheel well.  What are your measurements?  Thanks.
