Author Topic: E-Body Convertible Interior A-Pillar Trim  (Read 1642 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: February 20, 2013 - 03:20:51 AM »
As some of you may already know, my '70 Challenger Convertible is by-no-means stock, and I'm not trying to change that.  The prior owner's resto-mod "restoration" includes many non-'70 original parts, and aftermarket/performance stuff.  So I don't mind doing what I'm planning to do regarding the A-Pillar interior trim.  I wanted to replace both sides because the plastic had cracked at the screw hole at the lower end of the pieces.  Several years ago, I purchased original mint condition '70-'74 hard-top pieces because convertible pieces were very hard to come by, or were too costly.  Back then, I had read somewhere that the top could be cut off for convertible applications (I recently read that the same thing was done at the factory).  The only way I was able to get the trim off my A-pillars was to break it off in many pieces because it was "fused" to the windshield's urethane adhesive.  When I placed one of the hard-top pieces on the A-Pillar, I noticed that the lower screw hole was in a different location (higher up).  I was crazed and perplexed until I started doing some research here and elsewhere.  I now understand that there were two versions of the A-Pillar trim; one which was used in the 1970-71 cars, and another which was used in 1972-74 cars.  I believe the only differences were in the location of the screw holes and possibly the hardness of the plastic (1970-71 being harder than the later years).  I'm going ahead with using the HT pieces I have since they're in such nice condition.  I plan on drilling a new screw mount hole into the A-Pillars, and cutting the tops off the trim just below the top screw hole.  Any comments or suggestions on my plan and/or what tool/method would be best to do the cutting will be greatly appreciated.  My other concern is whether or not I'll be able to get the drill where I need to in order to drill out the new hole (the windshield is still in place, and I'd rather not have to take it out and put it back in just for this).  Pictures are of the two passenger side trim pieces.  I lined up the Pentastar and part numbers to show the screw hole location differences.  Interestingly, the part #s are the same.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline JayBee
Re: E-Body Convertible Interior A-Pillar Trim
« Reply #1 on: February 20, 2013 - 01:55:24 PM »
Sorry, no suggestions, I can just relate to what you're doing. I searched high and low for replacement convertible pillar trim with the lower screw hole. No luck BUT did find hard top ones that I've yet to get around to cutting. A friend of mine has a few hardtop sets and showed me the same part number on pairs with different screw hole locations. Yes, that truly was a learning day.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline wiging19
« Reply #2 on: February 20, 2013 - 03:48:39 PM »
 :popcorn:
Offline filmsurgeon
« Reply #3 on: February 21, 2013 - 01:31:10 PM »
Check out this ebay listing.  I happened to notice while looking at the seller's photos (4th photo enlarged is best) that he is selling two different versions of the A-pillar trim.  He claims that they are BOTH the earlier version.  Notice how the bottom screw hole is directly above the part number on the driver's side piece (bottom in 4th photo).  If the passenger side piece (top in 4th photo) were the earlier version, the bottom screw hole would be directly beneath the part number.  If these two pieces were put side-by-side (with the Pentastar and part numbers lined-up), the screw holes would not line-up; matching versions would have the bottom screw hole lined up.
http://www.ebay.com/itm/Mopar-1970-E-Body-Pillar-Molding-Cuda-Challenger-AAR-T-A-Convertible-Barracuda-/170991755947?fits=Model:Challenger&hash=item27cfe722ab&item=170991755947&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
Offline JayBee
« Reply #4 on: February 21, 2013 - 02:12:01 PM »
Nice catch. Got to be really careful when buying off e-bay. Unfortunately some people are not as educated in the differences and can get burned with this set.
John
2014 Toyota Avalon
