Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
how to fix a small chip
« previous
next »
Print
Pages: [
1
Author
Topic: how to fix a small chip (Read 606 times)
ff6849
Jr. Member
on:
February 21, 2013 - 10:54:18 PM »
Have small chip in my new paint job, the paint shop gave some of the paint in a touch bottle, how should I go about fixing the small chip, clear coat base coat FE5 Rallye Red.
Logged
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
jimynick
Resident
Re: how to fix a small chip
Reply #1 on:
February 21, 2013 - 11:11:51 PM »
How big is "small"? If it's an 1/8" or so, I'd use a fine tip artist brush and dab a wee bit of colour in the bottom and once it's good and dry, I'd do the same with a dab of the clear until the hole was filled right up. If the original painter put enough clear on it, once everything is good and hard, you should either be good enough or you could take some 2000 grit and very gently sand it smooth and repolish. Good luck
Logged
ff6849
Jr. Member
Reply #2 on:
February 21, 2013 - 11:34:12 PM »
very small about 1/16 x 1/8, but it is all the way through the primer
Logged
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
FY1Cuda
Sr. Member
Reply #3 on:
February 23, 2013 - 01:21:50 PM »
I agree with everything jimmynick said. You'll of course need the color and the hardener for the red paint. You can skip any reducer.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
