Author Topic: A/F Meter Recommendations  (Read 6034 times)
Offline cwestra
« on: February 23, 2013 - 12:55:33 PM »
I'm  looking to buy an air fuel meter to dial-in my 6 barrel carbs.  Does anyone have any recommendations on an affordable and accurate unit?
Corey - in Northern Indiana
Re: A/F Meter Recommendations
« Reply #1 on: February 23, 2013 - 01:01:30 PM »
I'm happy with my autometer version?
Offline David Weber
  • MAKING OLD NEW AGAIN AND NEW OLD
    • MODERN MUSCLE PERFORMANCE GROUP
« Reply #2 on: February 24, 2013 - 12:37:47 AM »
Are you looking to leave it or just tune with it?
This AEM combo gauge you can log data to your laptop. It is a Manifold pressure and AF gauge.
http://www.modernmuscleperformance.com/AEM_Wideband_Failsafe_Gauges_p/30-4900.htm
Thank You
David Weber
Modern Muscle 276-666-1934
Offline cudabob496
« Reply #3 on: February 24, 2013 - 03:00:47 AM »
So, how beneficial is it to get an A/F meter? Am I missing out on power
by not having one?
2011 Kawasaki Z1000
Offline bandt
« Reply #4 on: February 24, 2013 - 09:47:34 AM »
They are the by far the easiest way to get your carb tuned spot on. Summit has an AEM set up for like 170$. If you are coughing on a rich idle or think you are leaving hp on the table A/F will tell you.
Offline cwestra
« Reply #5 on: February 24, 2013 - 10:32:35 AM »
Nice system, but probably more than what I need.  Looking for something that I can install just until I get it tuned then remove.  Nothing permanent.  Don't think I need the fail safe feature, although it's cool.  Need wide band though.
For those of you who have dialed in your car with an A/F meter, I'm assuming there is no great way of hiding the sensor hole in the exhaust pipe.  Since I plan to remove the sensor and related components after dialing in I won't have to worry about hiding them but I will have the plugged hole in the pipe that would seem to be a negative with respect to originality.  I suppose that is unavoidable.
Also, do I need to monitor each pipe separately?
Offline Jamiez
  • Retro
« Reply #6 on: February 24, 2013 - 10:58:07 AM »
Normally an exhaust shop will put in a bung so you can easily swap the sensor in or out.
Monitoring each pipe separately will make it more easy to get it dialed in as you'll know exactly which needs adjustment.
If you're looking for a temporary solution, there are some options that let you insert the sensor into the tailpipe or there are inline couplings you can insert into the system (if you can get the pipes apart).
Offline cwestra
« Reply #7 on: February 24, 2013 - 11:00:16 AM »
That might be a good option for me.  Any recommendations on a source?
Offline Jamiez
  • Retro
« Reply #8 on: February 24, 2013 - 11:08:08 AM »
Offline cwestra
« Reply #9 on: February 24, 2013 - 11:20:59 AM »
I bought a FAST one (my meter and sensor are all FAST).  Here is on JEGS:
http://www.jegs.com/i/FAST/244/170620/10002/-1?CAWELAID=1710555159&catargetid=1784158868&&cagpspn=pla&gclid=COiXgvioz7UCFe4-Mgod-lEAug
Thanks.  Do you lose any accuracy by sensing so far back?
Offline Jesus H Chrysler
« Reply #10 on: February 24, 2013 - 11:30:33 AM »
If you have headers, just get another set of collectors and weld the bungs into them. When you're done simply swap your original collectors back on.  If you have a mint original exhaust you may want to consider picking up another cheaper setup so you don't ruin the original.  Otherwise have an exhaust shop weld the bungs on the inside of the pipe out of sight.  when you're done tuning you can remove the sensors and put plugs in.  The upside is your sensors will remain relatively new and you can use the system on another car, or sell it on.  Don't leave disconnected O2 sensors in the pipe because they'll get ruined fast.  BTW Bosch is known for high quality wideband O2 sensors.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline Adrian Worman
« Reply #11 on: February 24, 2013 - 06:36:39 PM »
I used an Innovate gauge in my challenger and I'm really happy with it, latest Bosch LSU4.9 sensor, they even have an iPhone link so you can record your drive and replay the AFRs in real time, amazing system :bigsmile:
Offline BS CUDA
« Reply #12 on: February 24, 2013 - 08:54:56 PM »
 :iagree: I have run the Innovate for 2 years now and love it - wideband, data logging, and an excellent tuning tool.
Offline getslideways
« Reply #13 on: February 26, 2013 - 11:42:10 AM »
I have used the AEM UEGO sensor in a few turbo projects with the analog gauge.  For tuning i don't think the analog gauge is necessarily beneficial, however for me personally when driving i like to get any idea of what the car is doing with a quick glance.  So for me the analog needle gauge is easier than the digital readout.  Then again, i have never liked digital dashes from the 80's either.
I have used an innovate setup before in the past with good results too.
For the challenger i will probably go with the AEM Failsafe for its ease of logging and adjustability, or the Analog UEGO again.
« Last Edit: February 26, 2013 - 11:48:40 AM by getslideways »
Offline cudabob496
« Reply #14 on: February 27, 2013 - 11:16:26 PM »
Saw on Summit a bung that bolts to your exhaust, after you drill a small hole. No more need to go to exhaust shop.
2011 Kawasaki Z1000
