I am in need of replacing my 1973 360 Barracuda's headers, the headers that are currently in use are Hooker competition long headers that hang to low on the drivers side in which I am always scraping/hitting speed bumps/dips with or when the suspension is bottomed out.Yesterday, I ground off/flattened about 1/4 of the tube diameter when going over a dip in the road and now are worn thru and leaking. Also, I am not a big fan of the tie rod passing between the 2 forward down tubes of this header. Can anyone recommend a header by manufacturer and part# that corrects the problem of the drivers side header from hanging so low. What I am looking for is a higher tighter header. Thanks
