Author Topic: Fibreglass panels on a street car, yes or no  (Read 3739 times)
Offline AUSAAR
Re: Fibreglass panels on a street car, yes or no
« Reply #15 on: March 13, 2013 - 01:05:00 AM »
does anyone know if you can get firberglass doors that use the original window runners etc (ie not lexan windows). just a fibreglass copy of the original steel doors?
cheers, Mat
« Reply #16 on: March 13, 2013 - 10:33:36 AM »
how much lighter are street weight panels over steel? and who makes good doors and guards in glass
cheers, Mat
I'm sure it vareis from Mfg to Mfg, but at least a few pounds per part. The lighter weight also makes them more prone to vibrational and heat damage.
cheers, Mat
Not that I've ever seen. The fiberglass doors lack the inner structure and reinforcement to support all the weight of the mechanism, guides, and glass. I'm sure you could add it in, but at that point you would be adding so much to them that the weight savings would be reduced or the maintanence of the tolerances in the parts due to flex would produce binds, breaks, or other issues.
