Author Topic: '70 Challenger Seat Tracks?  (Read 7285 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: '70 Challenger Seat Tracks?
« Reply #15 on: March 28, 2013 - 07:39:32 PM »
on the seat track bolts we use the square headed battery terminal bolt.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #16 on: May 07, 2013 - 01:36:46 AM »
Thought I'd share an update on my seat-track stud replacement.  In an earlier post, I included three links to possible replacements.
The one that worked the best was this: http://www.fastenal.com/web/products/details/0155067 (The others were not quite right).
Following are some photos showing one of the replacement studs/bolts in place (temporarily).  These have a shorter square neck in comparison to the neck on a standard carriage bolt.  They are perfect for the thickness of seat track.  These will be loosely secured to the seat track by using 5/16" push nuts.  These Grade-5 bolts were inexpensive (as you can see from the last photos of the invoice).  I only needed four because only the inboard studs were cut short by the previous owner.  Hope this helps others who might need a cheap, but effective solution to replacing their seat track studs.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #17 on: May 15, 2013 - 02:40:44 PM »
Hey Nice CAR!!   I believe your car was originally done by Ed Belfour's (ex-NHL goalie) shop in Michigan??
In your travels or research, did you discover where to get the tensioner strap for the cable that releases the track?   My driver side is missing and won't operate due to lack of tension.    Do you happen to know where I can find these?
Thanks .... CHAPS
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline filmsurgeon
« Reply #18 on: May 15, 2013 - 08:24:15 PM »
Thanks .... CHAPS
AMAZING, that you know who the previous owner of my car was!!  How???  Yes, the car was his, and done by his shop in Michigan; "Carman Custom".  They used to have a website, but it's not been active for quite some time now.  I never needed to search for the "strap", because my driver's seat had it.  (See photo).  If you can't find one, I'm sure (by looking at it) that you can probably easily make one.  I can take measurements of mine and let you know if you need.
