Author Topic: Should I change my oil in the spring or fall  (Read 1077 times)
Offline spamtank
« on: February 28, 2013 - 07:43:47 AM »
Here's a question that nags me.
My car sits for 4 or 5 months in a garage that gets down to ~40-50 degrees
1) Should I change the oil before in the fall, after I've finished driving for the winter (what I do now)
2) Change it in the spring, just before I start driving it
3) Drain the oil in the fall, and fill it with fresh in the spring? (occasionally I need to run it over the winter)
I'm sure there are purest that say change it every 3 months whether it needs it or not.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline cudabob496
Re: Should I change my oil in the spring or fall
« Reply #1 on: February 28, 2013 - 07:47:45 AM »
Seems it would be good to run it/drive it a few times during that 4 to 5 months. Even if you're driving is the cold.
2011 Kawasaki Z1000
Offline 73EStroker
« Reply #2 on: February 28, 2013 - 07:50:10 AM »
If you live in a dry climate like me then I just change in the spring and go.
Barry (Salmon Arm)
« Reply #3 on: February 28, 2013 - 07:51:35 AM »
I tend to change oil in the fall & remove the acidic oil before it sits then have clean oil in over the dormant period
Offline spamtank
« Reply #4 on: February 28, 2013 - 08:19:37 AM »
I do run it a few times over the winter.  Especially if I'm changing parts, tuning up, or otherwise.
That's why I think # 3 would be best, but then if it gets run over the winter that defeats the purpose.
 But they put so much salt down here in NH that I don't want to expose it to that by driving it around.
2013 RT Plus 6M
Offline spamtank
« Reply #5 on: February 28, 2013 - 08:20:50 AM »
That's my philosophy as well.
I'm curious what everyone else thinks.
2013 RT Plus 6M
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: February 28, 2013 - 09:21:36 AM »
Nice post.  :grinyes:
I better change my oil soon...  :misbehaving:
Offline polarbear123
« Reply #7 on: February 28, 2013 - 09:33:45 AM »
I cahange mind in the fall. In the spring i run it a few hundred miles and change it again.
« Reply #8 on: February 28, 2013 - 09:38:26 AM »
This is what I do for the same reason. Used oil has a number of nasty things in it. Might as well get it out of the pan if its going to sit.
If you ever do fire it up in the winter months, for whatever reason, make sure you let it run long enough to get up to temp and vaporize any condensation that has accumulated in it. Even if it is just idling in the driveway.
Offline Changin Gears
« Reply #9 on: February 28, 2013 - 01:20:49 PM »
I don't really have a ritual, usually during the summer though.
