Author Topic: beauty rings  (Read 1471 times)
Offline cudamadd
    • cudamad157071@gmail.com
beauty rings
« on: February 28, 2013 - 05:53:04 PM »
HI CAN ANY ONE TELL ME WHO MAKES THE BEST BEAUTY RINGS ? Ones THAT WILL STAY ON THE RIMS 15X6 RIMS THANK YOU  :clu :clueless:
Go 4 a spin Ya Why Not.
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: beauty rings
« Reply #1 on: February 28, 2013 - 07:19:05 PM »
I got mine from Summit.But I have 15 x 7 s.  :dunno:
Offline cudamadd
Re: beauty rings
« Reply #2 on: March 01, 2013 - 04:11:22 AM »
Hi if you have 15x7 what size do you have on the front.  ? And do the trim rings push all the way down to the base of the rim thank you . :aussie:
Offline Road_Runner
Re: beauty rings
« Reply #3 on: March 03, 2013 - 09:09:40 PM »
I have the 15x7 Wheel Vintique Ralleys on front & 15x8 on the rear.  I used the same trim ring on both.  They fit VERY tight on the front, no extra room at all but do leave a small gap on the back 8" rims.  I bouight mine at Summit so these are probably the ones being discussed.  Are you rims Ralleys or are you putting these on stock / plain wheels?  If Rallyes, I didn't realize they came in 15x6" width, are you sure of your measurements?  Are they stamped 15x6?
Here are my front wheels:
http://www.summitracing.com/parts/wvi-56-5712044
Here are the trim rings I used:
http://www.summitracing.com/parts/wvi-3003-p
The 7" rims have 4.25" of backspacing so if your 6" rims have 3.25" or less of backspacing the trim rings could work.  Hope this helped.
Later, Jim
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline cudamadd
Re: beauty rings
« Reply #4 on: March 09, 2013 - 07:28:05 AM »
Jim thank you for your reply. could you tell me what size tyres you have on the front and back of the car . Yep the rings will not go all the way down , So i might have to buy 15x7 rims  :cheers:
Re: beauty rings
« Reply #5 on: March 09, 2013 - 11:55:21 AM »
On my 15x 7 s . I am running P275/60R/15s   And that is on the back.
« Last Edit: March 09, 2013 - 12:02:08 PM by DoNotChallengeHer »
