Author Topic: Securing stereo in dash  (Read 3529 times)
Offline mojavered
  • Someday!
« on: February 28, 2013 - 11:30:01 PM »
Search did not amount to anything, so...
Installed an aftermarket stereo today.  Just slid in the metal sleeve, then the stereo.  It is not supported at all.  There is that hook that is between the stereo and ash tray, but not sure how to make it work.  Any ideas?  Thanks!
Jason
Offline wiging19
Re: Securing stereo in dash
« Reply #1 on: March 01, 2013 - 01:25:08 AM »
 :popcorn:
Offline spamtank
« Reply #2 on: March 01, 2013 - 09:40:44 AM »
Not sure if this is what you are asking, but the original radios had two screws holding them in from underneath:
If this is the hook you are talking about,the original radios had a stud on the right hand side with a nut that would support the back of the radio.
http://www.ebay.com/itm/370700966740
That hook attached to a stud on the original radio at the back, just below the red wire with the nut on it:
If you can come up with some brackets to accept those mounting locations, that should work.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline mojavered
  • Someday!
« Reply #3 on: March 01, 2013 - 10:21:57 AM »
Thanks for the post, perfect explanation with pics. I will be fabbing something up to work with that hook.
Jason
« Reply #4 on: March 01, 2013 - 11:59:10 AM »
I just left mine hanging in the sleeve. I have had it like that for years now with no problems.
Offline Katfish
  • 70 Challenger
« Reply #5 on: March 01, 2013 - 12:32:37 PM »
Don't waste your money on the factory bracket.
You can get an universal strap, most aftermarket radios come with them.
It's just a flexible metal strip with multiple holes for mounting.
Offline FY1Cuda
« Reply #6 on: March 02, 2013 - 07:51:36 PM »
The sleeve probably has some tangs near the front edges that you can bend with a screwdriver blade to keep it tight against the dash. Like MEK said, that'll probably do it.
Offline mojavered
  • Someday!
« Reply #7 on: March 05, 2013 - 12:52:19 AM »
That is the way it is in there right now, it just seems like it has a little bounce to it?
Jason
Offline Got JOB
  • Member since 2-14-06
« Reply #8 on: March 26, 2013 - 05:34:19 PM »
I secured mine by putting a small piece of wood between the dash frame and the sleeve (bottom of sleeve). Secured the wood to the dash frame with a screw. Then I secured the din sleeve to the wood by putting a screw in the bottom of the sleeve using a rachet wrench with a philips head bit. Will not move or bounce.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline Katfish
  • 70 Challenger
« Reply #9 on: March 26, 2013 - 06:23:06 PM »
Not visualizing that, got a pic?
Offline Got JOB
« Reply #10 on: March 26, 2013 - 06:38:05 PM »
Put the sleeve (din) in the opening and put a small piece of wood under the sleeve in the space between the sleeve and dash frame. Secure the wood to the dash frame from underneath and secure the sleeve to the wood from within the sleeve opening using a small ratchet or wrench with a phillips head screw bit. Then slide your radio in the sleeve. Sorry no pics.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline mojavered
  • Someday!
« Reply #11 on: March 31, 2013 - 01:52:06 PM »
I ended up just sliding the sleeve in without anything else.  Stays in there without problems and works great
Jason
Offline Mark8117
« Reply #12 on: April 16, 2013 - 12:19:39 PM »
I used the universal metal strap with mulitple holes in it and bolted to the upper dash and screwed it into the side of the new radio.  Does not rattle or squeak. :ylsuper:
« Reply #13 on: April 16, 2013 - 02:53:19 PM »
I know this was overkill but I wanted the radio coming in from the rear for better looks & clearance as well be solid...
http://www.cuda-challenger.com/cc/index.php?topic=21379.msg516377#msg516377
