Author Topic: Educate me about bellhousings  (Read 941 times)
Offline ChallengerHK
« on: March 01, 2013 - 01:38:44 PM »
I've decided to do a conversion to manual. My knowledge of automatics is pretty good, but my knowledge of manuals is...not so good  :bigsmile:
So, my first question is, I see several small block bellhousings available. Different size clutches, different size bearing retainers, some other differences. What do I need, and what is preferable? (I'm looking at 500 HP if I'm lucky.)
- Han Solo, Star Wars
Offline polarbear123
Re: Educate me about bellhousings
« Reply #1 on: March 01, 2013 - 01:53:12 PM »
http://www.mymopar.com/index.php?pid=71
What you have to watch out for is the crank it is much more shallow on an auto than a manual. The input shaft of tranny will have to be cut. Call Brewer's they are great to work with they will answer all your questions. 937-698-4259
« Reply #2 on: March 02, 2013 - 11:12:49 AM »
or the better way is to drill the back of the crank , it doesn't have to be centered if you use the Dakota pilot brg , this way you do not have to distroy yet another not replacable trans input shafts
« Reply #3 on: March 02, 2013 - 02:25:09 PM »
I'll be stroking it anyway (that doesn't sound right, but it's true nonetheless  :smilielol: ) so I'm assuming that I'll just get a crank with the right depth at that point.
« Reply #4 on: March 02, 2013 - 07:42:42 PM »
the clutch system I would use is a McLeod 11" 3 finger borg & beck / long style with a 130 tooth flywheel , the brg retainer for the trans should be the larger 4.80 " , there is a spacer ring to reduce to 4.35" if needed
Offline 71chmark
« Reply #5 on: March 06, 2013 - 06:46:00 PM »
Trimming the input shaft doesn't destroy it.  It just makes it a little shorter.
I may be schizophrenic,
« Reply #6 on: March 06, 2013 - 06:56:13 PM »
Nothing wrong with that...... ::)
