Author Topic: Changing heads  (Read 668 times)
Changing heads
« on: March 03, 2013 - 08:14:35 AM »
I had planned on rebuilding the 440 over the winter, but it didn't happen. Is it ok to stick new heads on the 15 yr old rebuild or should I leave them on the shelf until I do the rebuild?  :dunno:
Re: Changing heads
« Reply #1 on: March 03, 2013 - 08:52:21 AM »
Firstly 15 years means nothing , my car has had maybe 200 miles in 15 years LOL
 you really have nothing to lose by putting the heads on , if the short block is weak it may burn some oil if the rings are weak . Is the head swap an upgrade to a better head ?  If they are alum heads I would use a cometic mls gasket
Re: Changing heads
« Reply #2 on: March 03, 2013 - 09:06:07 AM »
I hear ya. In 15 years I probably have less than 10k on it.
440 stealth heads. Heads on it now are I think if I remember, 452's. It is a 76 engine. The main reason the rebuild didn't go ahead was me dragging my a$$ aquiring a forged crank/short block with a forged crank.
Re: Changing heads
« Reply #3 on: March 03, 2013 - 03:03:47 PM »
AT 10 K the engine should be healthy
Offline cudabob496
Re: Changing heads
« Reply #4 on: March 03, 2013 - 05:30:34 PM »
2011 Kawasaki Z1000
