So a 3/8 supply line will work with the existing 1/4 return, I wanted to update my fuel line anyway, so I am just going to use the old 5/16 as the new return and then connect that to the 1/4 return fitting on the sending unit, from the feed back I gather that should just work fine.
I did install a keep it clean wiring harness (a painless knockoff) so I have a dedicated circuit for the fuel pump. I ran the wire to trunk and tucked up just in case I would need it later down the road (I guess I am down that road). So switching over to electric fuel system shouldn't be all that difficult.
I live in one of the hottest places on earth, we see temp's in excess of 110', it was almost 90' this weekend so I am going to be fighting heat issues on regular basis. So in the long run this upgrade should work well for my circumstances. I do have a venting cap so I am not creating a vacuum or pressurizing the tank.
I was thinking of up grading my mech pump, but that is about the same cost of the electric pump, and having a return in the southwest desert just makes sense. Plus I really would like to install a FAST EZ EFI later so I am setting my fuel lines now if I want to make that switch later down the road too.
This is my first project and I couldn't of done it without all of your advise, so thanks again for solving another issue. I did my first big car show this week and got a ton ohh's and ahh's it was annoying though explaining that its not a Camaro or a GTO
