Author Topic: Fuel vaporizing issue  (Read 6541 times)
Offline cudabob496
Re: Fuel vaporizing issue
« Reply #30 on: March 06, 2013 - 11:43:37 PM »
This little puppy handles my 850DP Holley and 600+ hp just fine. Pressure is a steady 6.5 psi,
with no regulator.
http://www.summitracing.com/parts/crt-m4862/overview/make/plymouth
if need regulator, this works good:
http://www.summitracing.com/parts/hly-12-803/media/images
« Last Edit: March 06, 2013 - 11:48:59 PM by cudabob496 »
2011 Kawasaki Z1000
Offline BS CUDA
« Reply #31 on: March 06, 2013 - 11:48:09 PM »
with no regulator.
Yup - for now!! I ran that way just fine for awhile and then one day................ I now run with a bypass reg - 1/2" feed and 3/8" return.
Offline cudabob496
« Reply #32 on: March 07, 2013 - 12:47:57 AM »
ya, I don't go to the track, just run on the street
2011 Kawasaki Z1000
Offline ff6849
« Reply #33 on: March 30, 2013 - 10:18:57 AM »
update, installed the holley blue pump with return regulator, upgraded to a 3/8 supply line in-place of the 1/4 vapor return line using the old 5/16 supply line as my return. Pump is noticeably loud at idle but not at cursing speed. Car runs much better no more vaporization issues and it seems to have much better throttle response.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
« Reply #34 on: March 30, 2013 - 11:14:19 AM »
 :2thumbs:  Glad to hear you got it sorted out!
 I'm betting you will get sick of the noise of the Holley pump soon though. FYI the Mallory pump is MUCH quieter. :grinyes:
« Reply #35 on: March 30, 2013 - 02:18:45 PM »
You won't even hear the Mallory fuel pump with the engine off.   :grinno:
Offline msbaugh
« Reply #36 on: April 08, 2013 - 01:49:26 AM »
How do some of y'all run return lines with mechanical fuel pumps? Can you even run A bypass style regulator with the mechanical fp? I've just got the charcoal canister with my mechanical Holley pump. 3/8 feed- 1/4 return
Offline drewcrane
« Reply #37 on: April 15, 2013 - 08:22:40 PM »
I have the same question , can and how can I run a return line with a factory mech. pump? in the past I have run a fuel iflter with two outlets and run one back to the tank m\but there has to be a more sanitary way if possible?
Offline cudabob496
« Reply #38 on: April 15, 2013 - 09:57:49 PM »
don't think you need it. You can buy the appropriate size mechanical pump to give you the 6.0 to 7.5 psi you need at your carb. And if you're
getting more than 7.5, you can add a cheapy Holley regulator for about $30.
2011 Kawasaki Z1000
Offline drewcrane
« Reply #39 on: April 15, 2013 - 11:52:59 PM »
Ok so run the factory set up ,with out a return line,see how it runs,and if I have issues hook up the return line,
or run the return line with the factory set up with a fuel filter with two outlets and see what my fuel pressure is .
 :dunno:
My biggest concern is vapor lock with the fuel here has 10% alcohol
Offline cudabob496
« Reply #40 on: April 16, 2013 - 04:41:02 AM »
 :dunno:
I think if you run the line away from heat sources, you will be ok.
you can also insulate part of the line if necessary. I insulate the part
of mine that gets blasted with hotter air from the radiator. I have a gauge
inside my car similar to this:
http://www.summitracing.com/parts/atm-3361/overview/
« Last Edit: April 16, 2013 - 04:51:04 AM by cudabob496 »
2011 Kawasaki Z1000
Offline drewcrane
« Reply #41 on: April 16, 2013 - 09:05:56 AM »
ok I will take your advice and do more of a factory set up and see how it does I can always add an electric pump later ,thanks for the help :2thumbs:
