Author Topic: How to remove the steering wheel  (Read 2796 times)
Offline PB
« on: March 04, 2013 - 11:35:04 AM »
Hi,
My name is Paul and I own a Cuda '71 340ci and I unfortunatly broke the key in the cylinder key. I have to remove this latter and I would like to know, fisrt, how to remove the steering wheel. This is a wood grain one. My main concern is to unlock the nuts as per this photo.
Thanks
I guess that this topic has already been discussed... Sorry for that.
Paul
« Last Edit: March 04, 2013 - 11:40:02 AM by 4Cruizn »
Offline 4Cruizn
  • HEMI FISH
Re: How to remove the steering wheel
« Reply #1 on: March 04, 2013 - 11:41:36 AM »
The center cap pops off and there are nuts under it that are removed and the wheel comes off very easy.  The issue is the crush can as you will need a puller to get that off . . . .  :bigsmile:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: March 04, 2013 - 12:14:13 PM »
Don't forget the horn wire otherwise you pull it out of it's connector.
Offline PB
« Reply #3 on: March 04, 2013 - 02:01:10 PM »
Hi Guys,
Thanks for your prompt answers. You mean that I should pull the center cap ?
Offline msbaugh
« Reply #4 on: March 04, 2013 - 02:10:08 PM »
Yes pull the cap, then there will be I think 3 or 4 nuts to take the wheel off. Then go to your local napa or w/e and rent a pulling tool, you'll need to use it on the nut in the middle to remove the crush sleeve, you'll see it after you get the wheel off. From there I'm sure you can figure it out
Offline PB
« Reply #5 on: March 04, 2013 - 02:17:50 PM »
Thanks. Excuse my lack of knowledge but I have much more background with the A Body  :grinno:
I have a Friend who has a pulling tool. I will have it next Thursday.
Offline anlauto
« Reply #6 on: March 04, 2013 - 03:18:17 PM »
You'll need two pieces of 3/8 threaded rod to fit down inside the collar.
Offline JayBee
« Reply #7 on: March 04, 2013 - 04:08:22 PM »
Here's a pic of the 2 pieces apart. I carefully use a putty knife under the cap trying not to scratch the spokes.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #8 on: March 04, 2013 - 05:16:05 PM »
I made a video of this on my Challenger some time back when I had to adjust a sloppy indicator stalk.
1970 Dodge Challenger - Steering wheel puller
Excuse the music. I originally used a James Taylor song, but YouTube wiped it because of copyright. Now a random song is played each time instead.
Offline PB
« Reply #9 on: March 05, 2013 - 03:04:35 AM »
Thanks Guys for your advises. I am waiting for the parts (Key cylinder & so on) that I ordered last Sunday.
Russ, I saw your video and this is very helpful.
I will keep you posted
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: March 06, 2013 - 03:42:15 PM »
If you need help witht he disassemply of the colum and replacin the key cyilinder PM me your email address and I will send you a very comprehensive PDF on all the steps to rebuild a column.
A member here put it together a few years ago and it is awesome!
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline PB
« Reply #11 on: March 06, 2013 - 03:54:38 PM »
PM just sent to U.
Thanks  ;)
Offline PB
« Reply #12 on: March 07, 2013 - 09:49:16 AM »
Thanks Jason for your detailled document. This is very helpful  ;)
Offline PB
« Reply #13 on: May 14, 2013 - 06:01:25 AM »
Here is an update about the closed issue.
First, thanks a lot to all of you and mainly to Jason for his fantastic documentation that he forwaded to me.  :thumbsup:
After having changed the iginition key cylinder, I had to change the upper steering column bearing. It took me sometime to get it.
The fish is now back on the road  ;)
