Author Topic: Turn signals don't work  (Read 6076 times)
Offline Onewickedchallenger
« on: March 04, 2013 - 11:29:22 PM »
 :clueless: Well I am now hooking up my harness to my 70 challenger. I am hoping someone can help me out again. For the record you guys have been a big help on my other issues with my project. Here is the problem I have i am using the original dash wiring harness. My new headlight harness was purchased at year one I think. My headlights work, my hazard lights work, my break lights work, my parking lights work, I went to napa and bought a new turn signal and hazard tin two prong thingamajig. Put them both on and did not make a difference. (Bought the hazard one just to change out both at same time). When I change from left to right the turn signal lights on the dashdo not come on.It does not even make a clicking noise. When I put my hazard lights on both signal lights flash like they should, and makes the clicking noise. I am at my wits end.
Thanks
Offline Rich G
Re: Turn signals don't work
« Reply #1 on: March 05, 2013 - 12:15:38 AM »
The flasher in the fuse box should be for the hazzards. I know on the Cudas the turn signal flasher is by the ash tray.Should be the same on Challengers.  Did you change that one too?
« Reply #2 on: March 05, 2013 - 09:38:39 AM »
Yes I changed the signal flasher and hazzard flasher. I checked with my test light i am getting power to both prongs on the signal flasher.
Thanks
« Reply #3 on: March 05, 2013 - 09:48:25 AM »
One thing that is different for the turn signals is the ignition switch has to be ON.
« Reply #4 on: March 05, 2013 - 11:09:17 AM »
Yes key was on. Turned on heater to make sure.
Offline TinCuda
    • 'Cuda
« Reply #5 on: March 05, 2013 - 11:23:14 AM »
Do you have a stick or auto transmission?  Your turn signals run through your neutral safety switch somehow.  Check for a blown fuse.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
« Reply #6 on: March 05, 2013 - 12:05:27 PM »
 :clueless:Goes thru neutral safety switch?????? That I did not see coming. I do not have it hooked up yet. I have the starter relay hooked up, but not the NSS wired up. I need to order the NSSwiring harness I guess. Is there anything I can do to bypass it?
Thanks
Offline TinCuda
    • 'Cuda
« Reply #7 on: March 05, 2013 - 12:19:49 PM »
See if these wire diagrams will help you out.
They are for a 1971 Barracuda, but they should get you close.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline TinCuda
    • 'Cuda
« Reply #8 on: March 05, 2013 - 07:23:19 PM »
Take a look at this...
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
« Reply #9 on: March 06, 2013 - 09:37:38 PM »
Great help , thanks I will work on it this week-end.
« Reply #10 on: March 07, 2013 - 09:07:47 PM »
NSS should only affect the back up lights
If the hazards work you know all the wiring is working from the turn signal switch out , I suspect a problem with the turn signal switch if you can confirm both flasher units work in the 4 way & if you have power in & out of the new flasher & up to the column turn signal switch plug .
« Reply #11 on: March 07, 2013 - 11:12:48 PM »
After checking everything I am all most positive it is the signal switch, also found out my ignition switch is bad. I turned the key to the off position and still had power to the blue wire, (coil wire).
Again thanks for all the leads... Will order my switches next payday.
« Reply #12 on: March 08, 2013 - 11:08:37 PM »
Standard part # TW 7 is the right TS switch , check with Rock Auto for best price
« Reply #13 on: March 09, 2013 - 08:49:55 AM »
Chryco you are the man... Thanks
