Author Topic: Brakes question  (Read 808 times)
Offline stsom
Brakes question
« on: March 06, 2013 - 03:04:33 PM »
Can I use a 71 power brake booster/master cylinder in a 70 Cuda? With a 426...
http://www.bilfrik.com For us that never stopped playing with cars
Offline johannes
Re: Brakes question
« Reply #1 on: March 07, 2013 - 12:05:03 PM »
One thing to be aware of, is that the mastercylinder fluid output connection point will have buildt check valve for connections going to drum brakes.
This means that the front fluid conn point (going to the REAR brakes) will have check valve....= you will NOT be able to blow air back into the reservoir.
Assuming you run disc in front,....you should be able to blow air back into the REAR reservoir of the master cylinder... = no check valve.
As for how the brake fluid pressure gets distributed via the valves underneath the mastercylinder,... I don't know what differences exists....
Re: Brakes question
« Reply #2 on: March 07, 2013 - 08:59:35 PM »
I doubt the booster will clear the valve covers
Offline stsom
Re: Brakes question
« Reply #3 on: March 08, 2013 - 01:42:20 PM »
So Hemi and powerbrakes was not an option?
Re: Brakes question
« Reply #4 on: March 08, 2013 - 11:02:23 PM »
Yes but I believe they used a smaller booster or an offset one up a little , I may be wrong
