Author Topic: Dash Mounting Hardware?  (Read 2458 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: March 09, 2013 - 02:25:23 AM »
Can anyone tell me what the correct bolt/screw size is for mounting the dash?  Specifically, the four that are accessed through the defroster ports.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline filmsurgeon
Offline anlauto
Re: Dash Mounting Hardware?
« Reply #3 on: March 09, 2013 - 11:22:22 AM »
I buy a lot of parts from Hoover. Excellent guys to deal with  :2thumbs:
Offline filmsurgeon
« Reply #4 on: March 09, 2013 - 12:28:19 PM »
Yes, I too have purchased from them in past years.  I already have the two pivot bolts for the dash frame to side of the body, so don't really need two more.  The prior owner of the car used different clips and "screws" (he used hex key stainless machine screws w/stainless washers) for the upper dash frame to cowl.  So, I really just need to replace those, but Hoover's complete set is $18.50 + $4.00 shipping.  It seems a little much for 10 pieces of hardware.
Just found this, and it seems more reasonably priced.  http://www.rtspecialties.net/proddetail.asp?prod=1000300  Seems more reasonably priced.
Offline filmsurgeon
« Reply #5 on: March 09, 2013 - 04:55:18 PM »
Found this info on the moparts.org site.  Member was not 100% this was correct though.
* Pivot bolts under kick panels = 1/4-20 x 1" with a 1" captive washer
* In the vents = 10-24 x 1" with a 1/2" captive washer
Offline anlauto
« Reply #6 on: March 09, 2013 - 05:09:46 PM »
Sounds about right. I would say the bolts under the kick panels are longer then 1".
Searching around you should be able to find just the bolts you need. Try AMK Products, http://www.amkproducts.com/  it's where most of these vendors are getting their hardware...nothing like going direct to the source. :thumbsup:
« Reply #7 on: March 09, 2013 - 05:56:18 PM »
That's true but there's a 25 or 30 dollar order mininum.
Offline anlauto
« Reply #8 on: March 09, 2013 - 06:00:18 PM »
You're correct...I never noticed that because I buy in bulk a lot....I wish my orders were only $25  :roflsmiley:
« Reply #9 on: March 09, 2013 - 07:32:48 PM »
Stick with Hoovers. He ships out lightning fast. I usually get my stuff from him in 2 or 3 days.   :2cents:
Offline anlauto
« Reply #10 on: March 09, 2013 - 07:47:03 PM »
 :iagree: :worshippy
