Author Topic: 70 Barracuda Gran Coupe Refresh  (Read 78342 times)
Offline turbo224
Re: 70 Barracuda Gran Coupe Refresh
« Reply #135 on: March 06, 2014 - 11:06:14 AM »
Two more questions.
First, does anyone know what sort of modification will be needed to use a 72 header panel with a 71 grill?
And second, will a 71 headlight wiring harness plug into the main 70 bulkhead connector correctly? Or will I need to modify it? I might have a 71 challenger headlight harness laying around, will it be the same as the cuda since they both have four headlights?
~Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
Offline anlauto
« Reply #136 on: March 06, 2014 - 03:32:42 PM »
The 72 header will work, but the plastic screw retainers will not line up. You can "make something work" pretty easy.
The 71 harness will plug in. I'm pretty certain all the wires are in the same locations, but it's a good idea to double check. :2cents:. If not, simply change the wire location to match the 70 bulkhead.
Offline turbo224
« Reply #137 on: March 06, 2014 - 03:39:33 PM »
Good to know, my budget is getting pretty thin and I dont want to have to buy another header panel. Any idea if a 71 challenger headlight harness is the same?
Offline anlauto
« Reply #138 on: March 06, 2014 - 03:40:15 PM »
Yes Cuda/Challenger are the same.
Offline turbo224
« Reply #139 on: March 09, 2014 - 03:25:11 AM »
Made a little progress on the motor this weekend. Got held up because I'm not sure I have the right pushrods for these roller rockers.
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #140 on: March 09, 2014 - 09:06:04 AM »
Your Moving right along quick. Looks good..  :thumbsup:
Offline Sleepychallenger
« Reply #141 on: March 09, 2014 - 09:42:08 AM »
What rockers are you running?
Offline hemiken
« Reply #142 on: March 09, 2014 - 07:25:50 PM »
Hey Tyler, the engine looks nice. What camshaft are you running ? is it a solid or hydraulic camshaft ? Your rocker adjusters look like they need winding down on a fair few of them from the pictures, their is a method for adjusting rocker gear when it is adjustable buddy. :grinyes:
Offline turbo224
« Reply #143 on: March 10, 2014 - 09:55:12 AM »
I cant remember the cam or lifter specs off hand, i'll have to look when I get home. I dont think I have the correct push rods in there right now, so I haven't finished all the adjustments. Hopefully i'll get that all figured out this week.
Offline turbo224
« Reply #144 on: March 19, 2014 - 01:23:47 PM »
Metal work is almost done, about ready to start stripping off the old paint.
« Reply #145 on: March 19, 2014 - 01:38:11 PM »
Man, That looks familiar..... :bigsmile:
Offline hemiken
« Reply #146 on: March 21, 2014 - 03:24:30 AM »
I spy a 71 coming to life :thinkerg: :cheers:
Offline turbo224
« Reply #147 on: April 08, 2014 - 10:00:33 PM »
First coat of primer is down so we can check all the metal work. Then we'll be doing more disassembly for the final prime and paint.
Offline usraptr
« Reply #148 on: April 09, 2014 - 08:33:01 PM »
Looking good!  :2thumbs:
(Edited 8-1-17)
Offline anlauto
« Reply #149 on: April 09, 2014 - 09:16:22 PM »
What colour is it going to be ?
