Author Topic: Brake Booster Sizing?  (Read 591 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: March 11, 2013 - 08:34:25 PM »
Can someone tell me how brake boosters are measured? I assume the stated measurement pertains to the housing diameter (for instance: an 8" dual diaphragm booster would be 8" diameter). Is that measurement: the diameter of the back or front housing, or is it the diameter of the where the two halves join (which technically would be the largest diameter)? Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
