Author Topic: 475hp 512fpt Fiji Blue Twin Turbo Stealth TRADE up + cash FOR E-Body  (Read 1769 times)
Offline travbstealthy
Looking to trade this car for a decent E-body Willing to trade up of course...this car is worth 14-15k here is a description...
1992 FIJI BLUE RT/TT
Long Block
 -Forged crank
 -Pauter rods
 -Ray
Pampena pistons & rings
 -ARP main bearing stud kit
 -GT-Pro stage 3
port & polished heads
 -99 lifters
 -ARP head bolts
 -Port matched
lower intake
 -Polished valve covers and intake manifold
 -Fully balanced
rotating assembly
Boost & Exhaust
 -IPS 19T-HL turbos
 -Ceramic
coated exhaust manifolds
 -Huge GT-Pro FMIC kit
 -Greddy type-s
BOV
 -Stainless Tanabe 3" exhaust, dual outlet (no cats)
Fuel
 -Denso
720 injectors
 -Dual in-tank Walbro 255 pumps (hotwired)
 -Braded stainless
-6 feed & -8 return fuel lines
 -Aeromotive fuel pressure regulator &
gauge
 -GT-Pro dual feed fuel rails
 -Devil's Own stage 2 methanol injection
w/2.5 gal sump tank
Drivetrain
 -Polyurethane motor mounts
-Man-Trans 25 spline remanufactured tranny and t-case
 -GT-Pro t-case
brace
 -ACPT one piece carbon fiber driveline
 -3SX CV shafts
 -Spec stage
4+ clutch
 -Short shifter
 -Solid shift linkage
bearings
Electronics
 -AEM EMS engine management
 -AEM MAP
sensor
 -AEM intake temp sensor
 -Boost a spark ignition amplifier
 -MSD
spark plug wires
 -Greddy Profec B spec 2 boost controller
Suspension,
Brakes, Wheels & Tires
 -New oem ECS struts
 -Tein S-Tech
springs
 -3SX adjustable upper control arms
 -3SX rear steer
delete
 -Stillen cross drilled rotors front & rear
 -Stillen brake pads
front & rear
 -Stillen braided stainless brake lines front &
rear
 -BBS 18" 2 piece rims
 -245/35R18 tires (80% plus
tread)
Audio/Video
 -Pioneer DVD/NAV system
 -Pioneer 6 disc DVD
changer
 -Rockford Fosgate speakers front & rear
 -Alpine 4 channel
power amp
 -Viper paging alarm w/remote start
~2000 miles on a
fresh motor, turbos and drivetrain, the rest of the car has just under 81,000
miles. The motor was assembled by Larry McCoy at Automotion in Medford then
brought to certified AEM tuner John Reed at PSI in Portland Oregon. John is one
of the best & most respected AEM tuners around, if you've never heard of
John, google him. He dialed the car in with a very safe, conservative,
streetable tune making 464 uncorrected awhp @ 20psi. Turbos spool extremely
quickly to produce a VERY even powerband, it drives like a stock car until you
lay into it. The motor, fuel supply and drivetrain were built to handle big
power, larger turbos would easily put it at 600+ awhp.. The rest of the car is
in well above average shape as well, fresh paint about 6 years ago (high dollar
work). The interior is also in great shape, with the exception of a couple small
splits on the drivers seat. All power options work great, has the sunroof &
the A/C blows ice cold.
« Last Edit: March 14, 2013 - 06:12:16 PM by travbstealthy »
Offline tommyg29
Re: 475hp Twin Turbo Stealth 25k+mods TRADE + cash FOR E-Body
« Reply #1 on: March 12, 2013 - 10:17:33 PM »
Looks just like one I almost bought a few years ago, right down to the BBS rims, but that one had been built by GT Pro and had a lot of issues. Of course, the car I did eventually purchase is also a blue 92 TT. You have good taste.  :bigsmile:
Beautiful car. Good luck with it.
Wow, I just checked my old photos and that is the car I came this close to buying in ft. lauderdale 3 years ago. I took lots of pictures. It has a long history, but it sure was FAST. With the mods you listed it looks like you corrected the issues I mentioned.
« Last Edit: March 12, 2013 - 10:41:36 PM by tommyg29 »
« Reply #2 on: March 13, 2013 - 09:51:35 PM »
I saw it on ebay down in Fl but missed out on it. I guy named Mark from Portland bought it and completely rebuilt it with the 19t's and the aem ems tune. It runs GREAT! I love it...I've had a couple of these cars and this has been the best one yet. Spools up quicker than I ever expected and runs just like stock but much faster!  I'm glad I got it after it was built right. I was told that the fellow in Fl. had over 40k in the car with GT Pro and it never did run right. Mark did a great job building it and the guy's at PSI in Portland did a great job on the mild tune.
Still love the old E-body Muscle...I'm afraid of getting in trouble with this car
Offline tommyg29
« Reply #3 on: March 13, 2013 - 11:01:38 PM »
I still have a few dozen pictures of the car, and a manifesto the then owner wrote describing his issues. Lots of leaks, and smoke so bad he could no longer drive it, despite what I remember was a total of about $60k he had in the car IIRC.
At one time he dyno'd the car at almost 600hp and GT Pro claimed it as a record for that setup.
I decided against it after my tuner nephew advised against it, and I found another very similar car, but closer to oem, just a few months later.
That Stealth has taken a few cross country trips between owners and tuners!
« Last Edit: March 13, 2013 - 11:04:13 PM by tommyg29 »
