Author Topic: Running big wheels....295,305,315 Post your pics  (Read 1941 times)
Offline Aus_Cuda
« on: March 14, 2013 - 04:24:24 AM »
Many of the older threads dont show pics any more.
If your running 285, 295, 305, 315 or bigger show it off. Please add some basic detail such as rim width & possibly offset/spacers.
Thanks all...................
Offline 72440Cuda
Re: Running big wheels....295,305,315 Post your pics
« Reply #1 on: March 15, 2013 - 10:34:37 PM »
I'll bite.
Front: 15x8, 4 1/2" BS, Weld Draglite, 265/50-15 BFG (tire no longer available)
Rear: 15x10, 6 1/2" BS, Weld Draglite, 3/8" spacer, springs moved 3/4" inboard, 295/50-15 BFG
Looking to go to 18's soon
'72 Cuda 440/727 GV overdrive
Offline high perf mopar
« Reply #2 on: March 16, 2013 - 12:21:41 AM »
275/60-15 E/T 3 classic's 15x8 4 1/2 backspace,,,,235/70-15's E/T 3 classic's 15x7 4 1/2" backspace...the 70 series with the larger cross section compliments the wider 60 series,,large/wide rear tire/narrower same height front tire...wide and skinney's..
10.1" rear tread,,,7 1/2" front..28.06 height/27.9 height..
« Last Edit: March 16, 2013 - 12:33:00 AM by high perf mopar »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline drewcrane
« Reply #3 on: March 16, 2013 - 09:22:33 AM »
I am running 17 x8,s with a 4 inch bs, 275 /45 17 on all 4,s
Offline Jamiez
  • Retro
« Reply #4 on: March 16, 2013 - 01:59:01 PM »
295 50 R 15 rears, 235 60 R 15 fronts:
Offline dutch
« Reply #5 on: March 16, 2013 - 02:22:14 PM »
 :bigsmile:
*** Bart ***
« Reply #6 on: March 16, 2013 - 10:52:18 PM »
Wow dutch, breaking out the 12.50x15s, huh?
Below is 295/50 rear, 235/60 front. 15x8, 4.75 backspace all around.
Slight change up. 26x10 up front, 26x12 out back. Front 8" with 4.5" backspace. Rear 10" with 5" back space, springs moved in, '67 B body housing.
