Author Topic: silver 572 with red guts  (Read 138751 times)
Re: silver 572 with red guts
« Reply #405 on: July 13, 2015 - 05:05:45 PM »
Don't even want to think about it Brad lol, that was a big deal for me to get that installed, now i can move along with everything else.
Thanks Bruce
NEVER add it up , that way when the wife asks you can say I don't know?  :roflsmiley: ( That's been working for me so far?  :dunno:)
Offline cordodge
« Reply #406 on: July 13, 2015 - 05:19:36 PM »
Oh she knows, she is just being very good about it lol. Im sure she will remind me the first time i piss her off ( i have been a good boy for awhile now) maybe that works for her lol !
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline ToxicWolf
« Reply #407 on: July 13, 2015 - 05:30:32 PM »
Absolutely beautiful!  That stacked breater is sweeeeeeet.   :2thumbs:
Offline cordodge
« Reply #408 on: July 13, 2015 - 05:37:13 PM »
thanks toxicwolf, I still have some measuring to do on that, it's clear in the back but i think it touches the brace that runs across the hood. i never had time to screw with it before i flew back to work, i think i can make it work but may neen some more tweaking.
Bruce
2007  Dodge Ram 4x4
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #409 on: July 13, 2015 - 09:49:01 PM »
Nice Bruce.. Look at that bad boy sitting in there... Great work sir,, :bigsmile:
Offline cordodge
« Reply #410 on: July 13, 2015 - 09:53:52 PM »
Hey thanks john, it feels great getting that done. I see your moving along quite well yourself, I can't wait to see yours complete I think it's an awesome build your doin.
Bruce
2007  Dodge Ram 4x4
Offline cordodge
« Reply #411 on: July 14, 2015 - 06:28:22 PM »
Well i talked with bill from RMS and wow he is a great guy to deal with. I am using the flaming river rack (which is very nice) and it has a master spline and so does the steering column so when i centered the rack and the column the hole for the roll pin was out 90 degrees,  i believe the older racks Bill used were just splined and you could put the u-joint on anywhere you needed. so i called bill and he thanked me for bringing it to his attention and is sending me one with the holes moved.
Just have to say nowadays great customer service is hard to come by so when you speak with people from company's like RMS, Roseville & bouchilion to name a few
it's not hard to figure out why they are doing so well. :2thumbs:
Bruce
2007  Dodge Ram 4x4
Offline larry4406
« Reply #412 on: July 15, 2015 - 05:38:26 AM »
Very nice.  Where did you attach the crane to lift the body up to install the engine from below?  Most below install pictures I have seen use brackets attached to where the front bumper would mount.
Offline cordodge
« Reply #413 on: July 15, 2015 - 07:57:48 AM »
Hey thanks larry, well i took the advice of alan who has done a lot this way. there are two holes in the frame just in front of the k-frame bolt holes, i used a rubber coated big hooks and lifted from there never left a mark as there is not really a lot of weight, i just used your average 2 ton hoist and it was not under a lot of strain at all, when i lifted the motor and trans onto the front end that was a lot heavier it seemed. It was the first time i installed one this way and i will always do this way from now on, no messing around with anything like headers/trans/starter. took me about 30 minutes to have it bolted up and with a stock k-frame i am sure it would be quicker.
Bruce
2007  Dodge Ram 4x4
Offline cordodge
« Reply #414 on: July 31, 2015 - 09:06:30 AM »
Anybody know what P.S pump I would need to run my hydro boost system and also the rack & pinion on the alterkation? Just want make sure I order the right one.
Any help is appreciated
Bruce
2007  Dodge Ram 4x4
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #415 on: July 31, 2015 - 09:47:23 AM »
Bruce
Seen this thread yet??  http://www.cuda-challenger.com/cc/index.php?topic=107682.0;topicseen
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline YellowThumper
  • I left the snow for this?
« Reply #416 on: July 31, 2015 - 10:11:03 AM »
Bruce
My suggestion is to contact Alterk... Steering pressure requirements are first order of business. I imagine the braking does not utilize much fluid flow. I converted mine awhile back and am utilizing a factory 5.9 Magnum motor pump setup. Works smooth and steady.
Good luck.
Mike.
« Last Edit: July 31, 2015 - 10:31:44 AM by YellowThumper »
Offline cordodge
« Reply #417 on: July 31, 2015 - 11:14:18 AM »
Hey, thanks guys , I'm sure I will find the right info on here. This is a great site with great people.
Bruce
2007  Dodge Ram 4x4
Offline cordodge
« Reply #418 on: September 14, 2015 - 05:12:43 PM »
just a couple pics of the p/steering pump,alt and fan set-up. all the wiring is finished and is all working as it should, had a couple ground issues but nothing major. exhaust is finished minus the tips, brakes are bled going to bleed the clutch tomorrow. getting there just need a drive shaft and carb fill everything else and fire it up. :jumping:
2007  Dodge Ram 4x4
Offline roadman5312
« Reply #419 on: September 14, 2015 - 05:27:41 PM »
                        Lookin fine as frog hair.    :cooldancing:  Going to video first fire off ?
        :rebel:
