I am making up some reenforcement plate for my K-Frame. I am workign on the from sturut rod mounts.
Usually I see guys just weld a 1/8th inch thick washer around the hole (with only the outside welded).
My plan is to make a plate that extends well past the holes. I will weld around the edges of the plate with a few plug welds in the plate. My thoguth is that this will spread the force out to a greater area.
MY questions are:
1. Is there any merit to this plan?
2. I assume that there is no need to make the holed in the plate the exact same size as the whole in the K-frame, provided the existing hole is in good shape?
3. I know this area on the k-fram is not 100% flat, so can I justuse some heat in the plate to bend it into place after welding one side?
Here is a pic of the templates for the plates.
Thanks for all the help. This is my first real fab project and I am really enjoying it!
Jason
