News:
I got a cap for my 73 Cuda as I could not buy a new dash and a new 5 speed at the same time. Mine does have the indent for the "barracuda" plate on the pass side. I trimmed off all the old dead foam and vinyl that was curled up and made what was left level. I took some expandable foam (which was probably not necessary) and sprayed some in the vacant spots and glued in the pad like the instructions said. I did trial fit first, and you have to cut out the VIN slot. Unless you look hard, that is the only place that is noticeable that it is not real. Of course, it is not like a new dash, but didn't cost a grand either.
During the resto.........and now......
did you do yours in the car with the windshield out?
So no script or plate on yours
I thought mine was the cheap version but it does have the inset for the BARRACUDA emblem on the passengers side. I guess some are different. Pressing in the detent? I would call the maker and ask about that.
I had the windshield out and the dash in..........worked well. And it still is in the same shape today as when I put it in....The vin spot was already cut out in the pad........I glued it down in just a few places on the front and about 3 near the windshield bottom area.
