Author Topic: Legendary dash cap.. Not as easy as it looks?  (Read 10139 times)
Offline 74 challenge
Re: Legendary dash cap.. Not as easy as it looks?
« Reply #30 on: February 04, 2014 - 03:12:58 PM »
I got a cap for my 73 Cuda as I could not buy a new dash and a new 5 speed at the same time. Mine does have the indent for the "barracuda" plate on the pass side. I trimmed off all the old dead foam and vinyl that was curled up and made what was left level. I took some expandable foam (which was probably not necessary) and sprayed some in the vacant spots and glued in the pad like the instructions said. I did trial fit first, and you have to cut out the VIN slot. Unless you look hard, that is the only place that is noticeable that it is not real. Of course, it is not like a new dash, but didn't cost a grand either.
could you not just leave the spot for the vin and get some new rivets and attach it on top for a cleaner look? I understand the merrit of not doing this with a huge dollar car but for most what is the issue?
1-8-4-3-6-5-7-2
Offline dpcd67
« Reply #31 on: February 04, 2014 - 05:12:49 PM »
Yes but I figured you are not supposed to remove a vin plate. It would have looked better to put it on the cover instead of cutting a little window for it, too late for me now.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline Sleepychallenger
« Reply #32 on: February 04, 2014 - 07:18:49 PM »
During the resto.........and now......
did you do yours in the car with the windshield out?
Offline Tejas R/T
« Reply #33 on: February 04, 2014 - 08:24:19 PM »
 :popcorn:
Offline dpcd67
« Reply #34 on: February 05, 2014 - 12:26:40 PM »
I left the windshield in.
1963 Dodge M37 (3)
I ain't done yet.
Offline DAYLEY/CHALLENGER
« Reply #35 on: February 05, 2014 - 06:54:49 PM »
I had the windshield out and the dash in..........worked well.  And it still is in the same shape today as when I put it in....The vin spot was already cut out in the pad........I glued it down in just a few places on the front and about 3 near the windshield bottom area.
Dave or David
« Reply #36 on: February 06, 2014 - 05:10:39 AM »
So no script or plate on yours
« Reply #37 on: February 06, 2014 - 04:17:25 PM »
No...........not even a spot where it should be......but as a lot have said...the $120 or so vs the $800+.........makes a lot difference when you are building a driver car. And that was all I started out to do.  I have been lucky and won a few awards but with so few Mopars around here.........there isn't too much competition either.
Dave or David
« Reply #38 on: February 06, 2014 - 10:09:34 PM »
Do you think it is possible to heat that area and press in the name plate? Mine will be a driver but there are little things that I love on the car that I want to keep
Offline dpcd67
« Reply #39 on: February 07, 2014 - 11:49:55 AM »
I thought mine was the cheap version but it does have the inset for the BARRACUDA emblem on the  passengers side. I guess some are different. Pressing in the detent? I would call the maker and ask about that.
1963 Dodge M37 (3)
I ain't done yet.
« Reply #40 on: February 07, 2014 - 08:17:48 PM »
Where did you get yours? Was it the inset for the plate or the script?
Offline dpcd67
« Reply #41 on: February 08, 2014 - 12:26:46 PM »
It is an Accuform Plastics dash cap; it has a 4 inch inset on the right side so the Barracuda plate can be glued on to it.  I got it from a dealer on ebay.
1963 Dodge M37 (3)
I ain't done yet.
« Reply #42 on: March 19, 2014 - 09:50:56 AM »
For those of you that left the dash in, how much of the pad did you trim before putting the cap on? What adhesive did you use? How did you brace it until it was dried.
« Reply #43 on: March 19, 2014 - 07:41:07 PM »
If I remember right, there was a tube of adhesive with my cap.  I put it only in a few places to allow movement with heat and cold.  The pad had a few high spots so they were shaved down to level.  As you can see from the pics (old) there was the duct tape fix used too.
Dave or David
« Reply #44 on: March 19, 2014 - 11:14:21 PM »
thanks Dave. Im trying to relay the info back as much as I can to try and get the cap to look as good as possible till I can afford a real dash  :bigsmile:
