Author Topic: 4 speed fill plug  (Read 626 times)
Offline KillerBee
4 speed fill plug
« on: March 22, 2013 - 02:43:21 PM »
How tight should the fill plug be on a 4 speed transmission?
I noticed there is a small trickle of fluid coming out of the plug on my Challenger's 4 speed transmission, it is not a constant drip.
I did not use teflon tape on the plug's threads when I filled the transmission.
I have tried to tighten the plug in more but it seems the plug will continue to thread in and not get tight.
Should the plug be tightened until completely snug or do I need teflton tape on the plug's threads?
Thanks.
« Last Edit: March 22, 2013 - 02:56:38 PM by KillerBee »
Offline KillerBee
Re: 4 speed drain plug
« Reply #1 on: March 22, 2013 - 02:45:17 PM »
Double post
Offline jhaag
Re: 4 speed fill plug
« Reply #2 on: March 23, 2013 - 01:44:40 PM »
Plug should be pipe thread, so it should get tighter as you screw it in. Interference fit. Usually don't need a sealer, but if it leaks enough to bother you, I would use a paste teflon sealer from a tube versus tape. You might want to try another plug as well.
love 70 Challengers
Offline 4 speed fish
« Reply #3 on: March 23, 2013 - 07:06:56 PM »
The tranny should only be filled to about a 1/4 inch below the hole.I would re tap the hole and the put some  silicone sealer on  the  threads.
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #4 on: March 23, 2013 - 08:42:21 PM »
Quote
make sure you have a pipe plug (which has tapered threads) and not a conduit or straight thread plug.  If a pipe plug won't stop the leak then you should use a thread sealant.
The Brewmaster
