Author Topic: Replace your lower column bearing: Better and Cheaper!!!  (Read 67355 times)
Offline 72bluNblu
Re: Replace your lower column bearing: Better and Cheaper!!!
« Reply #45 on: July 06, 2014 - 02:00:49 AM »
ok... :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
I went our a bought the bearing (found a local source,$25).  Looks like it will fit the column ok, but it does not look like it will fit the shaft.
I measured both the bearing and the shaft, the inside diameter of the bearing - just less than an inch (0.998) and the shaft, just over an inch (1.003).
I am guessing I need to sand the paint of the shaft, and uhhh use a little force to get the bearing on????
I guess I thought it would just slide on????
Jason
Umm, you're talking about a .005" difference. If the shaft has paint on it, that's the problem. A little sandpaper and some elbow grease and you'll be in business. It's a tight fit, but it shouldn't need a press. I had to do a little clean up with some sandpaper too, only took 5 minutes.
« Reply #46 on: July 06, 2014 - 09:43:39 AM »
 :iagree: in addition that shaft I'll bet is not perfectly round either like the bearing is.
Offline CudamanTom
« Reply #47 on: July 06, 2014 - 10:50:15 AM »
Jason
Jason,
The bearing will just slide on. BUT the shaft has to be clean of any rust, paint or burrs.
I made the mistake of painting the shaft first. Clean the shaft, slide the bearing in place. I painted the shaft after I installed the steering column.
Worked perfectly.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline CUDA JAS
  • vroooooom!
« Reply #48 on: July 08, 2014 - 12:30:34 AM »
thanks guys.
I will keep sanding on the shaft and get it to fit.
I was just worried about taping on things, don't want to destroy the bearing or collapse the shaft...any further.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline CUDA JAS
  • vroooooom!
« Reply #49 on: July 09, 2014 - 10:27:22 PM »
thanks guys.
Jason
well, I may have got a little over zealous with my tapping, ok maybe I was more then tapping with my BFH.  I have the bearing just about where it needs to be...but the bearing is really tight, and does not turn very freely.   :eek4: :eek4: :eek4: :bricks1: :bricks1: :bricks1:
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
« Reply #50 on: July 10, 2014 - 12:24:47 PM »
oh and now I am concerned how I am going to get the lock plate on the shaft with the bearing in there...I think I am over thinking this....
 :swear: :swear:
74 'cuda 360/727
Offline CudamanTom
« Reply #51 on: July 10, 2014 - 01:04:15 PM »
Jason. So the outter part of the bearing doesn't turn freely?
If the bearing is tight on the shaft, that's fine and just what you want. But the outter part needs to turn fairly easy.
Offline CUDA JAS
  • vroooooom!
« Reply #52 on: July 10, 2014 - 01:09:50 PM »
Oh its tight on the shaft alright...but it also take a bit of force to turn the outer porting of the bearing now.
Jason
74 'cuda 360/727
Offline CudamanTom
« Reply #53 on: July 10, 2014 - 05:06:57 PM »
Jason
Hummm, you might have dinged it a little. I know I hit mine pretty good (my mistake) but seemed to rotate okay and checking for uneven movement. They seemed built pretty tough.
I guess it's what you feel is best.
« Reply #54 on: July 10, 2014 - 10:41:15 PM »
Before I put my bearing on, I took a Roloc fine grit on my pnuematic air tool and sanded it all over.
Then after that, I took a finer grit sand paper and sanded till it was smooth.
Slid the bearing on, and was done without any effort sliding it up into place.
« Reply #55 on: July 10, 2014 - 10:44:38 PM »
Did you hammer out the T end and try to slide it up?
Or are you trying to get the bearing to slide from top to down?
Top to down won't work. The shaft is thicker at the top area.
Ask me how I know. I ruined one trying that.
Offline CUDA JAS
  • vroooooom!
« Reply #56 on: July 11, 2014 - 08:34:53 AM »
I was going from the top down.
Did you destroy the shaft of the bearing.
At this point, I think I am just going to cut the bearing off and start over...I am pretty sure I ruined the bearing.  There goes $25 down the toilet!!
Jason
74 'cuda 360/727
« Reply #57 on: July 11, 2014 - 09:05:27 AM »
Jason
Ended up getting another bearing.
Hammer out the T and do what I did with a roloc and sandpaper.
Offline CUDA JAS
  • vroooooom!
« Reply #58 on: July 11, 2014 - 02:28:32 PM »
How did you get the bearing off?
Jason
74 'cuda 360/727
« Reply #59 on: July 11, 2014 - 03:32:30 PM »
Use a thick angle iron and a BFH.
