Author Topic: Gran coupe interior door panel inserts  (Read 1498 times)
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« on: March 24, 2013 - 04:49:21 PM »
Looking for the wood grain or red door panel inserts for the passenger side of my gran coupe to paint yellow. Anyone have these?
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline EB3-GranCoupe
  • BP23 U0B
Re: Gran coupe interior door panel inserts
« Reply #1 on: March 24, 2013 - 09:28:35 PM »
they are not easy to come by, and when you do they can be $$$.  they would not be hard to re-pop, but no one i know of is doing that.
  • BP23 U0B
« Reply #2 on: March 24, 2013 - 09:31:15 PM »
Yellowfin, I sent you a PM.
Offline tuff340GranCoupe
« Reply #3 on: March 25, 2013 - 08:49:33 PM »
if you look in the parts for sale section, I have a complete set of them that are all there. pricey as always, are you interested in mine? PM me back & check out my for sale add.
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #4 on: March 25, 2013 - 09:37:18 PM »
Thanks tuff, I really only need two pieces though. Passenger door and passenger rear upper piece. I'm trying to avoid buying a full set. $275 is more than I was hoping to spend for two pieces, otherwise I'd just buy the set from you.  If you are willing to trade some stuff, I can do that. 3piece gran coupe/cuda tail trim, gran coupe rockers. Etc
« Last Edit: March 25, 2013 - 09:48:38 PM by YellowFin »
« Reply #5 on: March 26, 2013 - 07:32:26 PM »
I see. I will watch this spring at shows & swaps for you but don't hold your breath for me. These are very hard to find period but the rears are easier to find than the doors. However, I do have one separate upper piece thats damaged & it may work for you since you are painting it. Let me know if you might want this one, it is cracked  :swear:
« Last Edit: March 26, 2013 - 07:34:20 PM by tuff340GranCoupe »
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #6 on: March 26, 2013 - 10:41:23 PM »
Yeah, if you have that cracked piece, perhaps I can save it.
Worse case, I could try to find some at mopar nationals in August if it doesn't work out.
  • BP23 U0B
« Reply #7 on: March 27, 2013 - 01:41:01 PM »
I wonder how hard it would be to re-pop them? It is very similar to exterior door-ding moldings, just with a brown wood-like-imitation finish with a metallic highlight bar above & below. Just cut to length, bend to fit, and glue on the metal tabs, then you are good to install.
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #8 on: March 27, 2013 - 03:04:44 PM »
Looks like a two piece stamped design. Shouldn't be hard to reproduce.
« Reply #9 on: March 27, 2013 - 08:13:30 PM »
yellow fin, Im going to PM you on this.
However, if this is repoped, remember you have to deal with making soem corners for the trim inside the door panels on the curves. I'm sure something can be repoped, just hope who does uses some original as the base.
« Last Edit: March 27, 2013 - 08:15:24 PM by tuff340GranCoupe »
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #10 on: March 30, 2013 - 09:16:29 AM »
Inbox cleaned, sorry for the hold up
« Reply #11 on: April 01, 2013 - 12:11:35 PM »
sorry yellowfin, just got back from a mini vacation, I will try & post the pic for you to your email only, so I will need your e-mail address, so PM me that & I will get the picture of the trim part
