Author Topic: Brake Line Set Options?  (Read 531 times)
Offline AMXguy
« on: March 24, 2013 - 06:14:18 PM »
I want to put a new set of front brake lines on my Challenger, '70 with power disc brakes.
I find an option between a 1 piece and a 2 piece " I " , what does that mean?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline anlauto
Re: Brake Line Set Options?
« Reply #1 on: March 24, 2013 - 06:57:23 PM »
Usually refers to the brake proportioning valve. Do you have a single block with a second block mounted on the frame rail, or a double block set-up mounted on the inner apron below the master.
FINE LINES is the absolute best for brake and fuel line kits. :2cents:
Offline AMXguy
« Reply #2 on: March 24, 2013 - 07:20:17 PM »
I have the double  piggyback set up mounted below the master.  that would be a  1 or 2 piece then?
I agree, Fine lines is where I'm going to order them.
« Last Edit: March 24, 2013 - 07:24:07 PM by AMXguy »
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #3 on: March 24, 2013 - 08:12:04 PM »
Or get them from Dave @ Roseville , I bet he buys them there too & you get a discount
Offline anlauto
« Reply #4 on: March 24, 2013 - 08:21:50 PM »
That would be considered a two piece :2thumbs:
