Author Topic: Garage floor question  (Read 1183 times)
Offline 06Daytona
« on: March 25, 2013 - 01:29:45 PM »
The floor in my garage is tile like most garages in Puerto Rico. When the house was built they thought that 12x12 tile that looks like brick would be nice :pullinghair: and it makes it a real pain to move an engine hoist, engine stand or anything else with wheels on it. It also means that I have to be careful where I put jacks or jackstands and it's a complete pain to keep clean.
I was  wondering if anyone has any experience with clear epoxy, or any other options for getting the floor smooth without pulling the old tile and up.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline Jamiez
  • Retro
Re: Garage floor question
« Reply #1 on: March 25, 2013 - 05:56:58 PM »
What about a product like Racedeck?  http://www.racedeck.com
I've never used them but they might be a quick install for you...
Offline 06Daytona
« Reply #2 on: March 25, 2013 - 06:54:46 PM »
I thought about something like that, but it all seems to be textured with diamond plate or little circles. I'd like to find something smooth so my creeper stops being a massage creeper
« Reply #3 on: March 25, 2013 - 08:52:15 PM »
What about a smooth tile overlayed on the existing tiles
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: March 25, 2013 - 10:31:12 PM »
You could "float" the floor with concrete leveler http://www.ehow.com/how_12218451_use-floor-leveling-compound-over-ceramic-tile.html
I have done it then placed tile, I am not sure how it would hold up to an engine hoist though.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #5 on: March 25, 2013 - 10:42:56 PM »
High psi LevelCrete coated with numerous layers of commercial epoxy would do the trick.
But if the tile are not stuck to the underlayment, you will have problems with cracking.
Is there a concrete slab under the tile?
Offline ek3
« Reply #6 on: March 25, 2013 - 11:36:57 PM »
you can apply a high build epoxy system. you will need to pour it out and float it with a squeegee . epoxy uses a mechanical  bonding process.  [etched surface or roughend by any means to stick ].. " gulf coast " makes some very good high build finishes. epo-plex i think is one or epolon. ppg makes some that will go on  @ 1/4" + or so .there are many ways to do it. you need to be above average in the ability to apply  this stuff . if you float the floor with skim coats, it may not have enough surface strength to use jack stands without scratching/digging  into the surface.
Offline 06Daytona
« Reply #7 on: March 26, 2013 - 01:20:55 PM »
I thought about putting down smooth tile on top of what's there, but I think it would get pretty expensive to get tile thick enough to handle all the cars and tools.
I'm starting to lean towards the rubberized floor panels if I can find smooth ones. That way I can do it a few rows at a time and I can always pull them apart if I ever decide to do a major garage cleaning again.
The ideal thing would be thick epoxy that could withstand tools and engine hoists but still have the tile look to it. The problem with that is that if it's too thin it can chip or peel.
I could always just put soft rubber tires on my tool boxes, creeper, picker and engine stands to smooth out the ride.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: March 26, 2013 - 04:48:46 PM »
I will diverge from the consensus and say go with breaking up the tile, and epoxying the cement floor for a smooth finish.
