What kinda 3rd member?
Author Topic: What kinda 3rd member?  (Read 1473 times)
Offline T/A Care
  • Pikes Peak Country
    • T/A Care's Website
« on: March 14, 2005 - 05:52:00 PM »
I picked these up a while back. They work fine. (These pictures were taken before they went in.) I've just seen a lot of discussions over time as to what is better; clutch or cone, 742 vs. 489, small yoke vs. large, pinion shaft diameter, gear wear pattern, etc..
Would you guys tell me what I have here, pros and cons?
Thanks.
Thank You Vets!
Visit T/A Care's Website
Romans 10:9-10
Offline 360 'CUDA
Re: What kinda 3rd member?
« Reply #1 on: March 14, 2005 - 06:00:55 PM »
What you have there is a MONSTER :thumbs:
The best case with the nasty 4:56 gears... running some RPM on the freeway?  :grinyes:
I take it burnouts and black line making are not a problem
Do you sometimes have trouble keeping your car on the ground? 8)
Offline T/A Care
« Reply #2 on: March 14, 2005 - 06:04:27 PM »
Yes, keeping it stuck is a problem.  I'm going to some cheater slicks!
Any ideas on it's make up?  I know it's a clutch type.  Is it the large pinion?  Wide yoke?  Any pros and cons?
Thank You Vets!
Romans 10:9-10
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #3 on: March 14, 2005 - 07:16:13 PM »
http://sybertek.us/moparsa2e/viewforum.php?f=18  will tell you everything you need to know on the 8 3/4  diff
« Reply #4 on: March 15, 2005 - 02:34:15 AM »
I can`t tell the yolk size but you have the strongest large pinion carrier with the strogest /clutch type sure grip , no cons I can think of
Offline T/A Care
« Reply #5 on: March 15, 2005 - 11:57:30 AM »
Thanks for the replies guys!
In trying to understand a little better, why do people ask for 489 cases, in the "Wanteds"?  Wouldn't they want a 742?
Thank You Vets!
Romans 10:9-10
Offline 67Vette427
  • My other car is not a Rambler
« Reply #6 on: March 15, 2005 - 05:36:32 PM »
I believe the difference is that the 742 case was last used in 69. The 489 is most common afterwards and is found in the e-bodies. 742 is stronger than the 489 but I never broke a 489.... People prob want a 489 for original purposes....
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Offline heminut
« Reply #7 on: March 15, 2005 - 10:05:50 PM »
The 489 case actually used a little bigger pinion, but it also used a crush sleeve to set the pinion bearing preload. The 742 case used shims to set the pinion bearing preload, which is a better setup for hard use. There are kits on the market now that eliminate the crush sleeve in the 489 and convert it to the better shim type setup.
1970 5.7 Hemi Cuda
« Reply #8 on: March 15, 2005 - 10:07:27 PM »
Ratech makes a spacer to eliminate the crush sleeve which is th eweak link in the 489 case , the part# is 4103 from Ratech
