Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Can you repair a window regulator?
« previous
next »
Print
Pages: [
1
Author
Topic: Can you repair a window regulator? (Read 635 times)
Fern
Full Member
on:
March 29, 2013 - 06:26:56 PM »
My window regulators when cranking the windows up stick. I will crank the window up and it will stop, then if I roll the handle back just a little I can crank it up some more. It will do this a few times until the window reaches the top.
I think it is just worn out and was wondering if there is a way to fix it?
Logged
Cuda Cody
Resident
Vancouver, WA
Re: Can you repair a window regulator?
Reply #1 on:
March 29, 2013 - 06:31:40 PM »
Your drivers door window, right? The drivers side gets used a LOT more than any other window. The gears are most likely wore out. I've tore them about and replaced gears to make them work, but it might be easier to buy a new seat.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #2 on:
March 29, 2013 - 07:23:21 PM »
Doesn't sound like the gears are stripped. Have you tried cleaning & lubricating the regulator, mechanism & guides? Are all the guides/rollers in good shape?
I solved something similar once with a little slickem.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
GranCuda1970
Sr. Resident
Rev 20:4. Mat 6:33 John 1:3 Mat 26:41
Reply #3 on:
March 29, 2013 - 11:13:48 PM »
I will eventually have to replace the drivers side one also. The gears on the sprocket are worn from years of use It rolls up nice and smooth but occassionally It will only roll down 2 inches or so and get stuck. next time i drive it and it works fine so is Off and on issue, Today it rolled down nice and smooth when I took her for a drive to the local DQ. Was nice and sunny and only roasted the tires once.
Last Edit: March 29, 2013 - 11:17:04 PM by GranCuda1970
Logged
Fern
Full Member
Reply #4 on:
March 30, 2013 - 01:57:06 PM »
I tried to grease them with no luck.
Where is the best place to buy them
and which brand will fit best?
Thanks
Logged
dodj
Sr. Resident
Reply #5 on:
March 30, 2013 - 06:40:55 PM »
On my driver's side regulator, the teeth were worn badly in only a two inch span. I built up the area with the mig and then re-filed the teeth.
Logged
1973 Challenger 440 4 spd
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
