Author Topic: 70 cuda exhaust  (Read 4440 times)
Offline aussie70cuda
70 cuda exhaust
« on: March 30, 2013 - 09:16:26 AM »
Hello i am new to this forum,i am from australia.I own a 70 cuda 440 six pack.It is a real v code car and is all numbers matching.It has 2 fender tags and is a red car red interior.I have owned the car for 26 years and the car has been in australia since 1973.It is a californian car (hope i spelt that correctly).It does not have the chrome exhaust tips and the exhaust exits under the rear valance.I am led to believe this is correct,is this so?Also if this is correct should it have rear mufflers on it?At the moment the car does not have them.It does mention some code on the fender tag about exhaust but cannot rember what it is at the moment.Any help is appreciated.
Offline Haddixj
Re: 70 cuda exhaust
« Reply #1 on: March 30, 2013 - 01:04:30 PM »
 Post some pics of the fender tag or decode it some around here will be able to tell you off Hand what the codes are.
Offline 67vertman
  • Member since 9-23-2005
Re: 70 cuda exhaust
« Reply #2 on: March 30, 2013 - 01:55:30 PM »
If the car was built for California, then yes it will have the exhaust exiting below the valance.  I think the code for it is N96  :clueless:  I will have to look at my tag to see.
Offline Jamiez
  • Retro
Re: 70 cuda exhaust
« Reply #3 on: March 30, 2013 - 02:08:08 PM »
N95 is the emissions control system (California carbs)
N96 is fresh air system (Shaker on Challengers, Air grabber on road runners, etc)
N97 is the Noise Reduction package (which I believe is the turn down exhaust tips)
N41 is Dual Exhaust
N42 is Bright Exhaust Tips (chrome)
Stock I believe that all E Bodies had resonators and mufflers, the placement of which may have varied across different years...I am not 100% sure
Offline CarelianCuda
    • http://bot.fi/3gu
Re: 70 cuda exhaust
« Reply #4 on: March 30, 2013 - 02:14:51 PM »
It's N97 Noise Reduction Package: http://www.hamtramck-historical.com/images/dealerships/SalesmansPocketGuides/1970/Pg%20032.jpg
It includes Barracuda rear valance and turn down tip mufflers, so no N42 tips with that code on same tag.
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Offline anlauto
Re: 70 cuda exhaust
« Reply #5 on: March 30, 2013 - 02:17:32 PM »
Your Cuda left the factory with two restonators and two mufflers with turn downs under the rear valance. No tips.
Offline 67vertman
Re: 70 cuda exhaust
« Reply #6 on: March 30, 2013 - 07:26:57 PM »
Just like the lotto......I am always one number off.  :bricks1:
Re: 70 cuda exhaust
« Reply #7 on: March 31, 2013 - 02:10:29 AM »
Thanks for the help so far,years ago i was able to decode most of the fender tag from magazine articles but could not find any info about the exhaust.
Below is the codes off of both fender tags.
N95  N96  N97 R22 V1X CTD                          V6X  26  END
M25  M31  M88 N41  N85
C62  G31  G33  J25  J45  M21
V1X  A34  A62  B51  C16  C55
FE5  H6E4 000 C03  062534
E87 D21 BS23 VOE 123XXX
Offline CudaChris74
Re: 70 cuda exhaust
« Reply #8 on: March 31, 2013 - 07:02:07 PM »
Gran coupes had down turn tips, I remember buying a 1970 cuda exhaust for my 74 back in 1983 at Napa, i then cutout the valance for round tip's
I was busted for having glasspacks that exited the side, i was pulled over by a then rare lady cop, i was driving and saw her pulled over a buddy and as i drove by I revved it up, well she chased me down and pulled me over and said she didnt like her ball's busted...hahaha
Offline AARuFAST
  • AARuFAST
Re: 70 cuda exhaust
« Reply #9 on: March 31, 2013 - 07:54:21 PM »
Holi smokes batman that ride is loaded. Any pictures. Red on Red.
E-body owners dream car...
All California plymouth barracuda's, Gr Cpe's, Cuda's exhausts exited under the valance no matter where built.
Your ride had Resonators    N97 noise reduction package.
Only the AAR and T/A challenger exempt from resonators.
« Last Edit: March 31, 2013 - 07:56:07 PM by AARuFAST »
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Re: 70 cuda exhaust
« Reply #10 on: March 31, 2013 - 10:46:44 PM »
I knew it had alot of options on it.Whoever bought it new must of had a fat wallet.When i bought it in 1987 a truck driver owned it,he was using it as a daily driver.When i got it home i found all of the vacuum lines had been removed from the carbies and all of the linkages made to work as one?? It had one of those big yellow accel coils mounted on the inner fender and all of the wiring in the engine bay was butchered.Somebody had also added an electric fuel pump.It had hooker headers and alloy rocker covers.6 months after owning it i stripped it back to bare metal and rebuilt it.Luckily every thing was on the car just filthy.The car will never be a concoures car as back in the late 80s when it was rebuilt there was no information available here in australia so i had to look in magazine to see how it should look.Luckily i was able to use alot of australian chrysler clips etc for the wiring and hoses so it at least looked like it was factory.I was able to get the correct exhaust manifolds from a swap meet.You would be suprised what turns up at our swap meets.The other reason it will never be concoures is that i believe in driving it,thats what the were built for.I go on a cruise that is only for american cars and hot rods once a month,there are on average 300-400 cars at each cruise.The cost of the rebuild was very little as i did everthing myself except the paint work.Under all of the grime the interior was in good condition.I think anybody who is doing a car up should have ago as this way you can learn alot.
