Author Topic: clearance issues with shaker  (Read 718 times)
Offline leanburn
« on: April 02, 2013 - 08:33:47 PM »
i'm trying to get my shaker from six pack performance to fit but it seems my combo is way to tall. motor is a smallblock, performer intake with an adapter to run a thermoquad. i removed the adapter and just let the carb sit on my intake and it's still to tall. i think the holleys are shorter but i really like this carb. do i have to switch to a stock intake to run the thermoquad carb?
Re: clearance issues with shaker
« Reply #1 on: April 02, 2013 - 11:19:20 PM »
even though carbs are manufactured but a number of different companies somewhere along the line they all agreed on 3.5" tall , the best fix would be a 71 - 85 or so 360 4 bbl intake with the spreadbore carb pattern / base
Offline leanburn
« Reply #2 on: April 03, 2013 - 12:47:57 AM »
Thanks chryco. Am i going to see a power loss with one of these intakes? Do you know approximately how much height difference there is between the two intakes?
« Reply #3 on: April 03, 2013 - 01:23:22 AM »
not sure on the height but I would guess around 1.5" taller with the RPM assuming that is what you have . yes you will see a power loss to But the factoryintakes are one of the better intakes available for the small block
Offline leanburn
« Reply #4 on: April 03, 2013 - 02:12:19 AM »
Wow. 1.5". That would solve all my issues for sure   Thanks
