Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
The Good Stuff
Member's Restoration Projects
(Moderators:
4Cruizn
Oldschool
1970 'Cuda Gas filler neck color??
« previous
next »
Print
Pages: [
1
Author
Topic: 1970 'Cuda Gas filler neck color?? (Read 5108 times)
usraptr
Sr. Member
on:
April 03, 2013 - 08:31:37 PM »
I'm getting ready to install the gas tank filler neck and need to know what color the flange that is under the license plate is supposed to be. The previous owner removed and cleaned it before I bought the car. Is it the tail panel color, body color or bare metal? Also, the filler tube inside the trunk. Same question. I assume it's supposed to be body color as it was probably already installed when the trunk was painted, but I'm not sure. Lastly, the trunk latch mechanism. Same question. I know the bolts that attach it are body color but what about the mechanism. It seems the ones I've seen are bare metal but I'm not sure if that is correct. I've attached pictures of the items I'm concerned about. Thanks for your help.
Logged
1970 Plymouth 'Cuda. Matching numbers 440 U Code, 4 speed pistol grip, Rallye dash, AM 8 Track, Shaker hood, 15 inch rallye wheels, Dana 60 4.10, Super Track Pak. One of 134 - 440 "U" coupes codes built in 1970 and one of 100 - 440 Super Track Paks built in 1970.
Restoration pictures at:
http://spanks4thememory.smugmug.com/Cars/70-Cuda/7240639_M24oi#465274575_2MBqW
(Edited 8-1-17)
"usraptr" = United States raptor - bird of prey = United States Bald Eagle. FYI, somebody else thought of it first so I had to drop the "O" in raptor.
usraptr
Sr. Member
Re: 1970 'Cuda Gas filler neck color??
Reply #1 on:
April 04, 2013 - 10:42:00 AM »
Somebody? Anybody? All you have to do is pull down your license plate and look and then open your trunk and look. Help please??
Logged
(Edited 8-1-17)
CudamanTom
Resident
Reply #2 on:
April 04, 2013 - 11:19:57 AM »
Mine was not painted. I'm betting none are, especially around where you fill up. Don't need paint chips getting in the gas.
Logged
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
usraptr
Sr. Member
Reply #3 on:
April 04, 2013 - 01:57:11 PM »
Thanks Cudaman. Anybody else?
Logged
(Edited 8-1-17)
brads70
C-C.com Expert
Reply #4 on:
April 04, 2013 - 01:59:17 PM »
On my Challenger ( if that helps? ) the filler neck looks to be a galvanized or zinc plated finish, sort of like the fuel tank?
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #5 on:
April 04, 2013 - 02:20:16 PM »
Those parts are never painted.
Logged
dutch
Sr. Resident
Reply #6 on:
April 04, 2013 - 03:16:20 PM »
I think they are leaded. Supposed to prevent static electricity.
Logged
*** Bart ***
usraptr
Sr. Member
Reply #7 on:
April 04, 2013 - 07:30:10 PM »
Okay, thank you regarding the filler neck. Agreed, no paint.
What about the trunk lock mechanism? Bare metal, painted or zinc plated?
Logged
(Edited 8-1-17)
HP_Cuda
Hit the skinny little pedal on the right!
Sr. Resident
Mopar or No Car!
Reply #8 on:
April 04, 2013 - 07:38:15 PM »
When I put mine in it's not painted and it looks like a zinc finish.
Logged
anlauto
Permanent Resident
Reply #9 on:
April 04, 2013 - 09:11:07 PM »
Trunk latch goes in just as pictured. It's true that often times the bolts were body colour, sometimes it's even been documented that the bolts have been a different body colour presumably from the car before or after on the assembly line.
Logged
usraptr
Sr. Member
Reply #10 on:
April 05, 2013 - 10:47:49 AM »
Thank you anlauto. I greatly appreciate the info.
Logged
(Edited 8-1-17)
AARudy
Jr. Member
1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
Reply #11 on:
May 02, 2013 - 02:32:17 AM »
Bare not painted , galvanized ... They are finally reproing them too..
With a foam gasket
Mine looks white in this photo, but it's new metal..
Last Edit: May 02, 2013 - 02:37:20 AM by AARudy
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
The Good Stuff
(Moderators:
4Cruizn
Oldschool
