Author Topic: Stray Voltage in the Radiator Fluid?  (Read 8491 times)
Re: Stray Voltage in the Radiator Fluid?
« Reply #15 on: April 08, 2013 - 07:20:10 PM »
Did they originally come with a body to block ground?
My '73 did.  :2cents: Small block 318
« Reply #16 on: April 08, 2013 - 10:39:44 PM »
Here's a thread on moparts discussing grounds & the ground strap... picture below is said to be of early production 70 model with insulated strap, someone stated "same as b-body" so this was nothing new.
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5437714&Main=5361844
« Last Edit: April 08, 2013 - 10:45:17 PM by Bullitt- »
« Reply #17 on: April 13, 2013 - 09:01:28 AM »
Kinda unrelated bu thow did you mount the rad ? Alum doesn't do well flexing & will quickly crack if mounted ridgid to the body , all factory cars will alum rads use rubber mounts to isolate body flex .
Offline ShelbyDogg
« Reply #18 on: April 18, 2013 - 11:55:30 AM »
I know it isn't factory, but I always use a Negative battery cable that has a ground pigtail off of it that I connect at the front headlight harness grounding bolt, by the battery tray. It is right next ti the radiator. Never had any stray volatges. I also put a ground stray from the rear of the driver's side head to the frame under my feet.
If you remember basic electronics, electrons flow negative to positive. Our grounds are actually powering everything, so I treat them as a supply. Switches on the positive side are simply a valve to let the electrons flow back to the battery.
Think of it this way and you'll never have a problem.
Offline Tonker1
« Reply #19 on: May 02, 2013 - 11:14:30 AM »
I entirely forgot about my radiator for a while, I've been working on a couple of drive train issues.
Currently my radiator is not mounted, the shroud got bent during shipping and had to get sent back. I should have taken some measurements before I sent it back, because without it I cant tell if it will conflict with my battery tray.
I do like the idea of the grommets. For that I was thinking:   bolt, washer (larger in diameter then grommet), grommet, radiator, two nuts. I'd hate for the grommet to come out.
Although my radiator isn't mounted it is grounded. They should of slapped the heck out of whoever assigned the conventional current to be out of the positive and into the negative!
Back when my car wouldn't start when I first started to redo my harness I spoke to some guys at my local auto shop. Their response was they charge $121/h, they gave me some pointers for free and I had it going that day. There other speciality is radiators. I spoke to them again today, got the same response about the money and they gave me some more free pointers. This is a business that has a serious aversion to accepting money! Apparently the most common cause for stray current is acid/base imbalances in the radiator fluid. This comes from putting in new fluid or in particular changing for green to red fluid which was recommended for my Aluminium radiator. Apparently using radiator flush and draining isn't enough to balance out the old fluid. So the theory is, the guys have only ever seen two genuine cases of stray current and that I should leave the car be for two or so weeks and occasionally run the engine to mix the fluid around and it should resolve it self! It all working it self out sounds good to me.
Thanks for the help so far
« Reply #20 on: May 02, 2013 - 12:06:17 PM »
I used well nuts to mount my rad, cheap and worked great! :2thumbs:
http://www.spaenaur.com/pdf/sectionC/C147.pdf
On the bottom I used stock rad rubber thingys? found them at a wrecking yard laying on the ground? Common parts. Milled a slot on a piece of thin plate and bolted it to the saddle. The rubber sits in the bottom of the rad perfect and keeps it from moving around.
Offline Tonker1
« Reply #21 on: May 18, 2013 - 09:02:48 AM »
Car work has slowed down a lot in the past couple weeks, I'm reaching crunch point at uni with exams in a couple weeks and whole bunch of assignments due in the near future.
Awesome photos as usual Brad, I ended up using regular grommets as my mounts weren't thick enough for well nuts.
The radiator is mounted, it looks much better now that it's sporting two 14" fans!
To the other folk in the Southern Hemisphere, the guys at Aussie Desert Cooler are awesome to deal with. A lot of the guys who compete for burnout king at Summer Nats use their radiators.
There is quite a gap between the radiator and radiator support. I want to increase the efficiency of the radiator, so the gap needs to be filled. I was thinking of using some industrial hight temp rubber. Are there any other ideas out there?
I would give an update on stray current but I entirely forgot to check and it's rapidly approaching 25 Fahrenheit outside.
Pic 1, Radiator: http://s1161.photobucket.com/user/Tonker1/media/33RadiatorInstall_zps6fc00195.jpg.html?sort=6&o=2
Pic 2, The Fans: http://s1161.photobucket.com/user/Tonker1/media/34TheFans_zps2b27dc97.jpg.html?sort=6&o=0
Pic 3, The Gap: http://s1161.photobucket.com/user/Tonker1/media/35RadiatorGap_zps5641e105.jpg.html?sort=6&o=1
