Hi Mike, I'm sure there will be others that will be more helpful than I but let me first ask what type of driving will you be doing? What do you have for gears in the car now? I'm not too sure about the carbs that came stock but I think the Thermoquads on the 340s were like 750cfm? If that is so, your 500 is way small for a good top end. Is the Torker a single plane manifold? For the street I would go with a dual plane manifold. The Torker is good at higher RPMs but will bog off the line, not as crisp off the line. Some like the Air Gap manifolds, sounds good in theory. The factory 340 manifolds were supposedly pretty good too from what I understand.
