Author Topic: What are dimensions of fuel tank, Want to build an aluminum tank  (Read 1470 times)
Offline 74BlueFish
What is the width of a Barracuda tank?  I can figure the shape and size from the tank straps but need to know how wide it can be built.   Thinking on going with fuel injection so want a tank with a pump inside.
Thanks,
Dan
Dan
Offline R/T hedkace
Re: What are dimensions of fuel tank, Want to build an aluminum tank
« Reply #1 on: April 06, 2013 - 09:40:54 AM »
If anyone can confirm that a cuda and chally tank are the same dimensions, mine is out of the car and I can take some measurements for you today.
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
Offline johannes
« Reply #2 on: April 08, 2013 - 05:40:40 PM »
Just be aware that the fuel tank shows quite a bit when looking at the cuda ....from behind...
A square looking shiny box might not look as good as you'd like...
Just my  :2cents:
Offline eddiemech
« Reply #3 on: April 08, 2013 - 10:36:14 PM »
I'm restoring my '70 AAR 'Cuda, so I went out to my garage with my tape measure. The dimensions of my tank are: Flange length-26 1/4"L X 22 3/4"W X 11 1/2" Deep. The tank itself is about 1" smaller all around, but if you're going to weld up the seams arou :newbie:nd the edges of your tank, then the flange dimensions should work. Hope this helps. :newbie:
Offline 74BlueFish
« Reply #4 on: April 09, 2013 - 01:31:36 PM »
Thanks. Eddie.  That's what I needed
If it looks too out of place. Then maybe I will paint it
Thanks all
Dan
Offline sprecks
« Reply #5 on: April 10, 2013 - 12:44:12 PM »
If you want to use the factory tank you may try modifying it for the fuel pump. Look at page 1 towards the bottom to see how I put my pump in the tank.
http://www.cuda-challenger.com/cc/index.php?topic=86814.0
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline IroquoisPliskin
« Reply #6 on: April 27, 2013 - 03:44:13 AM »
Hi guys, I don't want to get this conversation out of track, but I don't want to start a new topic for my question. Can you tell me how much fuel can be filled into a '71 'cuda tank. I can't even fill 10 gallons in. Is that correct? That would be very small considering the consumption. Thanks!
(OO[ [ [ ] ] ]OO)
Offline 74BlueFish
« Reply #7 on: April 27, 2013 - 08:38:30 AM »
i've read where they say they are 18 gal.
Dan
