Author Topic: 1st Time Poster - 1st Mopar - Engine dies when put in gear  (Read 13104 times)
Re: 1st Time Poster - 1st Mopar - Engine dies when put in gear
« Reply #30 on: June 24, 2013 - 03:24:22 PM »
another thing to try is inserting a piece of wire into the idle air bleeds to restrict the holes there , this often Cures low vacuum stalling issues . think of the 6 pack as a 4 bbl the cenrer carb does most of the work the secondaries are just along for the ride . there are idle mix screws in the base of the outboard carbs though often hidden behind steel plugs , I go underneath & drill a small hole from an angle & pop out the plugs to access the idle mix screws , the rear carb I base line about 1/2 turn out from the bottom , once it is in place it is very difficult to adjust ,the front is easy though .
Offline black68gtx
« Reply #31 on: June 26, 2013 - 12:24:32 PM »
I had the same problem...finally adjusted the accelerator pump (Holley Carbs) and it works fine.
How To Adjust The Accelerator Pump On Holley Carburetors
