Author Topic: Chrysler 8 3/4 rear axle rebuild. (NEED TIPS)  (Read 3143 times)
Offline 71CudaDrew
  • Newbie
« on: April 06, 2013 - 05:35:38 PM »
Ok guys so I am new to the site ...kinda... but for sure new to rebuilding a rear axle off of a 71 cuda...(does not seem all that complicated). But it does not have posi trac or sure grip.  :feedback: :feedback: :feedback:I have a 440 6 barrel going into the car so I want to make sure everything is at least sufficient enough to take to a drag strip on a off day  :burnout: . Can you guys give me any tips or suggestions on how to go about rebuilding and adding/modifying the rear axle to at least achieve better than stock.  :newbie:
Re: Chrysler 8 3/4 rear axle rebuild. (NEED TIPS)
« Reply #1 on: April 06, 2013 - 07:13:21 PM »
Depending on your budget  you might be further ahead getting a new Dana from DrDiff (Cass) After others on here giving me the same advice that's what I did and sold the 8 3/4 while it was still in one piece.
Offline jimynick
« Reply #2 on: April 08, 2013 - 12:06:52 AM »
Man, you sure know how to hurt Brad. Wish I had one.  :sadwavey:
« Reply #3 on: April 08, 2013 - 07:35:13 AM »
Just passing on advice others gave me when I was considering re-doing the 8 3/4. The bare Dana without the disc brakes ( your 8 3/4 drums will bolt on) was around $1800. Doesn't take long to dump that into a 8 3/4...?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: April 08, 2013 - 11:09:11 AM »
True that!
Offline jimynick
« Reply #5 on: April 08, 2013 - 11:22:56 PM »
Oh, no argument; I'm just suffering from diff envy, that's all.  ;)
Offline Jamiez
  • Retro
« Reply #6 on: April 09, 2013 - 06:19:11 AM »
My understanding is that rebuilding the diff and setting it up correctly needs some specialist tools and knowledge.  I've never tried it myself but I've heard it's a job best left to the professionals.
Offline 73440
« Reply #7 on: March 06, 2017 - 07:40:27 AM »
With this book , think I would try the rebuild.
http://www.themotorbookstore.com/jeep-dana-chrysler-differentials.html
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 73sixpack
« Reply #8 on: March 06, 2017 - 05:51:54 PM »
8-3/4 are one of the easiest to set up, toughest part is getting the pinion depth right, (pulling the big bearing off, often multiple times, to change the shim). Don't worry too much about strength of the 8-3/4 (489 or 742) unless your doing 4 grand clutch drops, mine held up with no problems in 8 years of drag racing with an automatic and slicks @ 1.70 60' times, almost lifting the front wheels. And they're lighter than the Danas.
« Reply #9 on: March 06, 2017 - 06:25:04 PM »
He must be done by now. The thread is almost four years old?  :grinyes:
Offline jimynick
« Reply #10 on: March 07, 2017 - 09:47:12 PM »
 :bigsmile:  ka-ka occurs!
« Reply #11 on: March 18, 2017 - 07:59:46 AM »
But thanks for the link 73440, I bought it.
Offline 73440
« Reply #12 on: March 18, 2017 - 08:48:13 AM »
SA 170 from S A Design is also a good book.
http://www.themotorbookstore.com/high-performance-differentials-axles-drivelines-how-to-book.html
Being the shade tree parts changer " mechanic " I am, reading thru FSM's and books and C-C and friends helps me to tackle projects.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
