News:
Thermal fan clutch is hard when cold. As it heats up and the car goes faster, there should be less need for the fan to turnas there is more air being passed across the radiator anyway. So it should freewheel more at higher rpm's
Am I the only one that thinks this is bass-ackwards?......no need for fan when coldThat being said you may need a new clutch fan but the fan has little to do with cooling at highway speeds. I'm guessing you have flow issues, either coolant or air.
does the fan seem to be pulling air thru the radiator as it should? Does the air flow increase immediately when you blip the throttle? Got a shroud on it and is the fan positioned properly in the shroud so it is not too far inside the shroud or not deep enuf...?
I think you have air in the system.I would idle the car between 1800 and 2000 rpm's with the radiator cap off and let the system burp.I had the same issue and this work for me.A friend of mine once ran water with a hose with some pressure starting from the lower radiator hose to flush the system in the reverse order.
some good points here so how do I know for sure all air is gone?
that was my idea as well... when driving @ say 50mph the temp seems pretty stable. just looked into the cooler and there`s junk in the channels, so that could very well be the problem. It`s not glogged up all the way but no 100% passage either. The block was hot tanked before rebuild, but the rad has nothing done to it other than a flush before installation.
