Author Topic: Clarification on ZDDP oil additive  (Read 1693 times)
Offline 7Dcuda
« on: April 08, 2013 - 07:47:45 AM »
Am I correct in that ZDDP oil additive is necessary for ALL flat tappet lifters, whether they be solid/mechanical or hydraulic?   I ask because I have a MOPAR Purple Shaft Hydraulic Cam with Hydraulic flat tappet lifters and want to ensure the necessity of using a ZDDP additive.  (70 Cuda/miild street build 440)
If i do need ZDDP for hydraulic lifters, does Valvoline VR-1 have high enuf zinc levels or do I still need to add a ZDDP additive in addition to the VR-1?
Also, is 20/50 in the VR-1 too thick?  Should I use the VR-1 10/30 instead.
Offline 72cudamaan
Re: Clarification on ZDDP oil additive
« Reply #1 on: April 08, 2013 - 08:48:06 AM »
Yes,zddp is needed for ALL flat tappet cams. VR1 is a good oil to use with plenty of zddp in it already. 10-30
would be plenty for a mild build.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 7Dcuda
« Reply #2 on: April 08, 2013 - 02:27:47 PM »
Thanks for the response.  Just want to make sure if I need the additive with the VR-1 or not.  Theres alot of mixed info. on this subject in this forum.
« Reply #3 on: April 11, 2013 - 04:16:27 AM »
what is the rating on VR1 10-30 ?
 If it is SM or SN it has low ZDDP , the 20-50 oils often have the SL rating with higher zddp levels
Offline 7Dcuda
« Reply #4 on: April 15, 2013 - 12:54:51 PM »
Its funny you ask about the API Rating on the VR-1 10-30......The spec. sheet on the Valvoline web site does not provide an API Rating for the VR-1 10-30.  But the spec. sheet does show the same Zinc/Phosphorus levels in the 10-30 and 20-50.  I currently run the VR-1 20-50 but would like to switch to the 10-30 since Im reading that 20-50 is a little thick for a non-racing motor.
As a result of all this I called Valvoline and talked to them about their VR-1 oil.  Valvoline assured me that with respect to the VR-1 Racing Oil there is the perfect amount of Zinc/Phosphorus in both the 10-30 and 20-50 for flat/solid lifters and if using either DOES NOT require additional ZDDP additives...running the oil alone is sufficient......and that applies to both regardless of the API rating.   So with that said I will be switching to the 10-30 in my 70 Cuda/440/4 speed.  Hopefully this helps clarify this subject for others as well since there is alot of varying info. on this subject on this forum.
« Last Edit: April 15, 2013 - 01:21:39 PM by 7Dcuda »
Offline don340-4
« Reply #5 on: April 15, 2013 - 03:37:18 PM »
  7Dcuda, thanks for that great information I also use Valvoline VR1 in my engines, 20-50 in the hot summer months, 10-30 in the cooler winter months.
   :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #6 on: April 17, 2013 - 11:11:11 PM »
i use brad penn oil
Offline dutch
« Reply #7 on: April 18, 2013 - 12:17:05 AM »
can anyone shine a light on Kendall 20-50 GT?  My shop here stated no problem when the cam has already been broken in.  :dunno:
*** Bart ***
Offline Strawdawg
    • Vortex Buicks
« Reply #8 on: April 18, 2013 - 11:28:00 AM »
http://www.phillips66lubricants.com/documents/conoco/industrial_oils/Ken%20GT-1%20High%20Performance%20MO%20(Ti)%20TDSw%20778549.pdf
look at the bottom table under 20-50.  It should be fine unless you have super stiff valve springs
Offline dutch
« Reply #9 on: April 18, 2013 - 12:48:32 PM »
thanks  :2thumbs:
*** Bart ***
