You don't have any adjustment with the stock set-up. The movement is probably because that valve is closed, with no real pressure on the spring and the lifter has bleed off a little pressure. The rocker that won't slide probably has the valve opened a bit and has more pressure on it. If you heard ticking with the engine running, might just be a lifter not building up pressure completly. Could be time for an oil change or a bad lifter
