Author Topic: Fuel pump  (Read 690 times)
Offline trouble
Fuel pump
« on: April 10, 2013 - 06:19:45 PM »
I'm having a problem reinstalling my fuel pump.
 Someone told me I Should remove the hex Nut below the Fuel pump,then I would be able to install the pump.
Is that correct? What exactly is that hex nut?
Re: Fuel pump
« Reply #1 on: April 10, 2013 - 07:23:16 PM »
I assume you have a big block?
To remove the hex nut, you will need a large Allen wrench. (I'm sorry, I forget what size).
The pushrod will then fall out. Just use some grease on the pushrod end to hold it up in there, and you can get the fuel pump in.
Offline trouble
Re: Fuel pump
« Reply #2 on: April 10, 2013 - 07:35:34 PM »
Do I push the rod up through the hole that  I removed the hexnut from?
Can I use a Screwdriver to push it up?
Also thanks for your help!
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Fuel pump
« Reply #3 on: April 10, 2013 - 08:51:43 PM »
no need to remove that hex plug, coat the rod in grease and push it up with your fingers
Offline trouble
Re: Fuel pump
« Reply #4 on: April 11, 2013 - 06:13:50 AM »
Ted,thank you that worked.
How tight do I make the bolts on the pump,I don't want to break them.
Re: Fuel pump
« Reply #5 on: April 13, 2013 - 08:41:01 AM »
About as tight as a spark plug 20-25 ft lbs max
