Author Topic: What Lube to use on Plastic Window Guide Tracks?  (Read 550 times)
Offline Katfish
  • 70 Challenger
« on: April 12, 2013 - 08:34:43 PM »
70 Challenger,
Replacing the door glass,
1) What is a good lube to use on the vertical tracks where the plastic guides slide?
2) The whole plastic assembly rotates in the glass, should the part that inserts through the glass be stationary once tightened?
Thanks
« Last Edit: April 12, 2013 - 08:36:45 PM by Katfish »
Offline Cuda Cody
  • Vancouver, WA
Re: What Lube to use on Plastic Window Guide Tracks?
« Reply #1 on: April 12, 2013 - 09:01:52 PM »
White lithium grease
Offline jimynick
« Reply #2 on: April 12, 2013 - 10:59:53 PM »
:iagree:  Commonly called Lubriplate.
