Author Topic: Re: E-Body leg room, or lack of...  (Read 3689 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: April 15, 2013 - 06:07:47 PM »
Regarding driver's front bucket seat: For those of you who may be having an issue with a lack of leg room, there has been a recent discussion on the Moparts Forum that you may find interesting.
I have been fairly active in posting to the thread in hopes it will help those who are looking for a simple solution.  My first post starts about 1/3 the way down in the thread.  My most recent contribution (04/15/2013) has the most detailed info and photos.  Enjoy.
Here is the link:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=7658449&page=0&fpart=all&vc=1
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline johannes
« Reply #1 on: April 17, 2013 - 04:42:58 PM »
Good effort ! Thanks for sharing.
I found my best sitting position by installing a smaller steeringwheel, and removing the crush can.
Then shimming the steering column ca 1/2 " downwards using small U-shaped pieces of plywood....
What I need, is someone making custom frontseat plastic backside....
If you look at a modern Merzedes, you'll se that the back of the front seats are curved inwards (frontwards) allowing more legroom for the passengers. (Or kneeroom is a better description)
Yup,...more kneeroom in the backseat is what I need....
Offline BIGSHCLUNK
« Reply #2 on: April 17, 2013 - 05:08:10 PM »
Installing a TUFF Wheel really helped me...........  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Matt70
« Reply #3 on: April 17, 2013 - 06:08:57 PM »
Im 5'8" did not think this was a problem  :smilielol:
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
« Reply #4 on: April 17, 2013 - 06:25:58 PM »
The 6-way seat helped me.    :thumbsup:
Offline Mopar_Mudder
  • I'm a llama!
« Reply #5 on: April 23, 2013 - 10:10:25 AM »
I made brackets just as filmsurgeon posted, I made them 2" from hole to hole so I would gain 2" in seat placement.
Well it all seemed like a good idea but their is a problem. You can not slide the seat back that much further because it hits the seat belt retractor. I think all I gained was about 1" until it the retractor. Looks like I am going to have to go to a smaller wheel.......
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline filmsurgeon
« Reply #6 on: April 24, 2013 - 04:00:26 PM »
Interesting.  I hadn't experienced that issue when my seat were in the car.  However, the prior owner did NOT have seat belt retractor covers installed, and I found that he had relocated the driver's belt retractor almost a full 2" closer to the door.
  • I'm a llama!
« Reply #7 on: April 24, 2013 - 04:07:25 PM »
If the cover was not on it would problably solve the problem. I might play around with it and see what I can do.
1971 Hemi Cuda
  • I'm a llama!
« Reply #8 on: May 06, 2013 - 10:00:48 AM »
Wanted to update that this week end I pulled the seat belt retractor off and was able to drill anther hole in the retrator that moved it 1" further to the rear of the car. This let the seat come back another 1". Now between the two mods I think it is accepteable with the oringinal wheel still on it and I can drive it. Smaller wheel would be better yet but I want to keep the original.
1971 Hemi Cuda
Offline high perf mopar
« Reply #9 on: May 11, 2013 - 08:25:11 PM »
just installed the extensions today in my 71 barracuda    :2thumbs:    followed filmsurgeon's guide,took about 1 1/2 hours,pretty straight forward,, much easier 4 me to enter and exit the car with a rim blow wheel..im 6'4" 200 lbs...at 54 my flexiblility is not what it used to be,neck,among other things,,in fact after entering the car i actually moved the seat forward a bit..
did not have to grind down the dimples,,counter sunk with a 9/16" bit,,2 holes only..2 1/4" ctr to ctr..used 3/16 x 1" bar and the tapered bolts..seat belt retractor was not an issue..THANKS...
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #10 on: May 28, 2013 - 05:41:50 PM »
Guys,
I'm 6'4" 250 lbs, and have owned and driven 5 Challengers over the years.  I've found the simplest solution, that makes the a very comfortable driving position is to put about 1.25 inches of spacers, (I've used all kinds of things, but large nuts work pretty good), under the front seat post and it reclines the seatback, giving you much more room between you and the steering wheel, and provides more thigh support, which I find more comfortable.
Give it a try, it may be just the ticket for ya, if not, then nothing lost.    Just loosen the rear bolts some (not all the way) and remove the front bolts.  Lift the front posts out of the floor and put a spacer over the posts and set them back through the floor.   Climb in and see how it fits, add more, or less depending of your needs.   Then just tighten up your bolts....  1/2" deep well with a short extension.
Good luck and let me know what you think.
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
