Author Topic: Hemi motors, where to buy?  (Read 8336 times)
Offline MizzouRT
Re: Hemi motors, where to buy?
« Reply #15 on: April 24, 2013 - 12:49:02 PM »
Indy Cylinder Head offers a wide range of Mopar crate engines and gives you a ballpark idea of what various combinations are going for (pricing is shown on their web site or in monthly ads in Mopar Muscle, etc).
Two examples:
426 Hemi 475hp / 500 TQ all-iron $15.5K
526 Hemi 650hp / 623 TQ aluminum heads, pump gas $20K.
I suspect there are both better and worse deals out there if you look hard enough, but these price points should give a good idea of what things cost.
Daily Driver: 2013 Challenger SRT 6 speed
Toy: 1970 Challenger
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #16 on: April 24, 2013 - 04:07:46 PM »
Wow this stuff can break the bank quick!
How much do original era hemis go to if you can find one? If I needed  to I can fab up my own headers that's not a issue for the 440 conversion but I think I would just go with a Hemi. My car is a 340 auto car. I believe the k member, engine harness will need to be changed? What else? Trans? Are the front end parts all the same?
You might consider doing business with Carlos over at Submission Engines  http://submissionengines.com/
He built my 605HP - 412cid -SB.  He's a GREAT guy, and knows ALL there is to know about Hemi Engines.  He specializes in them and even has his own Hemi block design.  I believe it would be well worth your time to give him a call.  He prefers dealing with customers the old fashioned way; in person and via phone, rather than via email/text.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline shoooter
« Reply #17 on: April 29, 2013 - 12:21:40 PM »
From what I understand all Hemi cudas came with a shaker hood?  I remember hearing that somewhere? So if I drop a Hemi I will need to change my hood also?
Offline ragtopdodge
« Reply #18 on: April 29, 2013 - 12:22:54 PM »
On 'Cudas, yes.
On Challengers, Shakers were an option.  That's why you see MOST Hemi Challengers with Rallye hoods.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline Haddixj
« Reply #19 on: April 29, 2013 - 03:12:54 PM »
Are you lookin for a bunch of horsepower Or just the look of a hemi? If you want it to look oe then 426 hemi for sure if your just looking for good hp and fuel economy go gen 3 hemi. 425 hp stock and will idle all day never get hot and reliable. An of the higher end hemi with 600+ hp will take race fuel and be hard on parts. I bought a srt 6.1 for my 70 but will probably sell it to fund the 71 project as I want to go oe style on it
Offline anlauto
« Reply #20 on: April 29, 2013 - 03:17:04 PM »
Call Tim Banning at FHO FOR HEMIS ONLY... :2thumbs:  http://www.forhemisonly.com/
Offline Oldschool
  • Member Since 9-05-06
« Reply #21 on: April 29, 2013 - 03:21:27 PM »
Not necessarily true. My Gen 2 Hemi has a little over 800 HP. It runs on pump gas. It has been together for over 7 years now. It gets driven regularly on the street between March and November. Never had a component failure of any kind.....    :2cents:    :cheers:
Ken  --  In Georgia
Offline Haddixj
« Reply #22 on: April 29, 2013 - 03:32:47 PM »
That's a strong combo 800 on pump gas is hard without alot of cubic inches. My race motor only makes 933 and is about 15:1 on methanol. Do you have a build thread or any details on the motor?  I am always interested in the motor builds. What kind Of car is it in? Any chassis alterations?
Offline Oldschool
« Reply #23 on: April 29, 2013 - 03:47:47 PM »
It's 528 CI.  Mopar 528 Mega Block. Eagle forged bottom end with 10.5-1 compression.  Indy aluminum heads with full CNC porting. Roller rocker gear. Comp Cams Custom grind roller. Ray Barton massaged crossram with two - Holley 750 HP's. Custom 2-1/4 headers. A little north of 800 HP and 760 TQ - on 93 octane pump gas. Several members here have seen it. I took it up to Carlisle in 2006 and met with a bunch of the C-C.Com folks. It is in a '69 Fastback - the car in my avatar. Lowered 2" with ladder bars. Car is backhalved. Runs 9.60's with no problems. I didn't build it to be a race car, just a quick little street car.  I could change the converter, rear gears, and carbs and go lay down a number. But that's not why I did the car.... :cheers:
Ken  --  In Georgia
Offline Haddixj
« Reply #24 on: April 29, 2013 - 04:21:34 PM »
Sounds neat and even better that you are able to drive it around
Offline shoooter
« Reply #25 on: May 01, 2013 - 02:02:45 PM »
Hmmm well to find a shaker hood on top of buying a Hemi might be too much. I guess you kinda need a shaker hood with the Hemi
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #26 on: May 01, 2013 - 06:27:40 PM »
A little north of 800 HP and 760 TQ - on 93 octane pump gas. Runs 9.60's with no problems. I didn't build it to be a race car, just a quick little street car.  I could change the converter, rear gears, and carbs and go lay down a number. But that's not why I did the car.... :cheers:
Wow! "Lay down a number"? Running 9.60's in "street trim" I think that you already have! :worshippy That's wickedly fast for the street!  :burnout:
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline high perf mopar
« Reply #28 on: May 01, 2013 - 10:14:28 PM »
any of tha MAJOR engine builders can help u as posted abobe but...anything in crate form from summit or other warehouses i would have dissassembled and clearance checked,,that was rec from several race shops because of the practice of "slap it together and get it out so i can bill it mentality",if u want higher horse motor buy the parts separate,have your machine shop check ALL measurements and assembly yourself.or your knowlageble buddy's..you will save ALOT of money,,,probably half!
thats what i did with the hemi i sold prior to this car,,,as another poster said,,u can easily get into the 800-900+ range on pump gas,,,,its all in the heads and roller valve train...
when i got it back from marino's machine here all the bearing,rings,pistons,rods were all marked where they go...just like painting by the numbers,,,,,actually it was...
same applys to 425-500 horse motors...who test fired it on the dyno?what oil and additives,flat tappet??trust no one!!!lol.$$$
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
« Reply #29 on: May 01, 2013 - 10:42:08 PM »
Aruzza even offers a Hemi that straightens out the push rod angles.
I've never seen it anywhere but it looks quite interesting.
