Author Topic: keep going through temp sensors  (Read 802 times)
Offline leanburn
« on: April 17, 2013 - 09:57:13 PM »
i rigged up my own relay for my fan useing a 180 degree sensor in the intake that completes the ground circut. i have fried 2 sensors now and don't understand how thats possible. when i disconnect the wire that goes to the sensor and hook it straight to ground the fan works awsome but for some reason when i hook to the sensor it works for twenty minutes and thats it, time for a new sensor. what am i overlooking?
Re: keep going through temp sensors
« Reply #1 on: April 17, 2013 - 11:15:25 PM »
use a relay , the load to ground probably eceeds the sensors capacity , trip a relay using the sensor ground then switch the load to ground through the relay
« Reply #2 on: April 18, 2013 - 11:54:42 AM »
I think you have the fan load current going through the sensor. The fan relay should be connected to a temperature switch, not a sensor. A sensor is a variable resistance.  :2cents:
Offline leanburn
« Reply #3 on: April 18, 2013 - 09:10:07 PM »
sorry i shouldn't have said sensor. it is just a temp switch.
« Reply #4 on: April 18, 2013 - 11:26:58 PM »
What are the contacts of the switch rated for? (amps)
Offline leanburn
« Reply #5 on: April 18, 2013 - 11:45:14 PM »
Not sure. I assumed that these were designed for what I'm useing them for but I guess not. I should have known that it was to easy  :banghead:
